2 Replies Latest reply on Apr 26, 2010 12:25 AM by sudar1983_14
    index
    kumargobi
      Dear All,
      In indesign cs3 Add index topics using below javascript code. This Source are to get topics from only character style content. But I want to get a topics in some xml tags. for example
      <index> addcontent</Index>
      How to get Xml Element content in javascript or xpath?
      I am using below codes
      "app.findGrepPreferences.appliedCharacterStyle = "Inx";
      var myFinds = doc.findGrep();
      var myHowManyEntries = myFinds.length;
      for (i = myHowManyEntries-1; i >= 0; i--){
      var myTopic = doc.indexes[0].topics.add(myFinds[i].contents);
      myTopic.pageReferences.add (myFinds[i],PageReferenceType.CURRENT_PAGE);"
      Regards,
      kumargobi
        • 1. Re: index
          HoneoyeFalls
          how about add a script to map tags to styles (if the style and the element tag are only used for indexing)?
          • 2. Re: index
            sudar1983_14 Level 2
            Gopi,
            Please try the following code.
            var scriptTitle="Add Index";
            var indexItems=new Array();
            var indexElementName='index';
            var aDoc=app.activeDocument;
            app.doScript (File(app.filePath+"/Scripts/Xml Rules/glue code.jsx"));
            getElements(aDoc.xmlElements.item(0));
            if (indexItems.length > 0)
                aDoc.indexes.add();
                for(var ind=0; ind < indexItems.length; ind++)
                    var myTopic = aDoc.indexes[0].topics.add(indexItems[ind].contents);
                    myTopic.pageReferences.add (indexItems[ind].texts[0],PageReferenceType.CURRENT_PAGE);
            else
                alert("There is no <"+indexElementName+"> element in the active document", scriptTitle);
                exit(0);
            function getElements(rootElement)
                var myCondition;
                var EntRuleSet = new Array(new FindElement("//"+indexElementName));
                __processRuleSet(rootElement, EntRuleSet);
            function FindElement(myRule)
                this.name = "FindElement";
                this.xpath = myRule;
                this.apply = function(myElement, myRuleProcessor)
                    indexItems.push(myElement);
            Arivu
