2 Replies Latest reply on Apr 24, 2009 1:34 AM by chocoanzak
    Downloading in Flex
    chocoanzak
      I am currently looking at the possibilites of downloading in Flex. I have a Client/Server set up where a file is produced on the server and then downloaded  in to the browser where the Flex client is sitting. However, I have had a number of issues with the set up of different browser (IE especially) therefore if I could keep all the functionality inside the flash player that would be ideal.
      I originally looked at the FileReference class and have found this ideal for downloading files directly to the user's hard drive. However, I also have the requirement to open a file using the user's default application.
      This would involve
      1) Downloading the content of the files (as a ByteArray) into Flex
      2) Binding it as a generic file type object
      3) Passing the object to the Browser so it can handle the opening of it
      I have successfully achieved retrieving and storing the ByteArray from the server but can not find any documentation on the further steps. I have read a lot about security issues but I wouldn't have thought that prompting the user for a file download was an issue (though I could be wrong on that one). I have found evidience it is possible in Adobe Air but the deployment of my application means I am limited to the Flash Player.
      Would anyone be able to suggest a way forward on this? I would really like to achieve a solution in Flex as I found it a very versatile language. If there isn't a solution any ideas if Adobe will support this in future. It seems like a good feature to have.
      Regards,
      William
        • 1. Re: Downloading in Flex
          Madhav Subedi Level 4
          Does simply telling browser to navigate to that file works for you?
          if so, then try following:
          navigateToURL(new URLRequest('file.zip'),'_blank')
          or
          navigateToURL(new URLRequest('a.txt'),'_blank')
          so that the browser handles it according to the file type.
          • 2. Re: Downloading in Flex
            chocoanzak Level 1
            Thanks for the reply. I am currently looking at the route you suggested but I found so
            many issues with cross browser compatibility that I was hoping an internal flex solution
            could solve my problem.
            I found an interesting article similar to your suggestion a while ago and the publisher managed
            to get downloading (from links) working across the browsers. However, testing it using IE7 now
            seems to break it.
            If anyone is interested:
            (http://thesaj.wordpress.com/2008/02/12/the-nightmare-that-is-_blank-part-ii-help/)
            I will endeavor to find a solution but alas I fear it will be using the browser and download links
            rather than inside flex.
