4 Replies Latest reply on Apr 24, 2009 5:42 AM by snowscreen
    Help with retrieving data from SQL with server side PHP-Script (Async Token)
    snowscreen
      May I dare to ask a question?
      I've established a connection in FLEX Builder 3
      to a MySQL database thorugh a communication with an
      automatic generated php script.
      But when I change the AS3 script, which communicates
      with the php script a problem occures.
      The data just gets lost through the process!
      Can anyone please tell me why, or correct the script beneath?
      private function getThis(searchString:String):Object
           * find the order parameters
           var temp:Object = new Object();
          var desc:Boolean = false;
          var orderField:String = '';
      var uidCol:String;
          var parameters:* =
              "orderField": orderField,
              "orderDirection": (desc) ? "DESC" : "ASC",
              "filter": searchString
            * execute the server "select" command
          searchRequest("FindAll", parameters);
               function searchRequest(method_name:String, parameters:Object):void
                  // add the method to the parameters list
               parameters['method'] = method_name;
               gateway.request = parameters;
               var call:AsyncToken = gateway.send();
               call.request_params = gateway.request;
               call.handler = searchReqHandler
                    function searchReqHandler(e:Object):void
                         if (e.isError)
                             Alert.show("Error: " + e.data.error);
                         else
                             i++;
                             for each(var row:XML in e.data.row)
                                 temp = new Object();
                                 for (var key:String in fields) //fields = row names
                                     temp[key + 'Col'] = row[key];
                                 uidCol = temp.uidCol;
                                 trace(uidCol); // // Gives>"656884" - the right answer from db
                             trace(uidCol); // Gives>"656884" - the right answer from db
                trace(uidCol); // Gives>null
            return temp //returns a empty object, with uidCol undefined.
      thanks in advance, snowscreen
        • 1. Re: Help with retrieving data from SQL with server side PHP-Script (Async Token)
          run,ryan! Level 3
          flex is event driven, I believe the trace is outputted by the following order
                                     trace(uidCol); // 4th output
                                 trace(uidCol); // 5th output
                             trace(uidCol); // 6th output
                    trace(uidCol); // 1st output
                trace(uidCol); // 2nd output
                return temp //3rd output, return value, an empty object obviosly
          • 2. Re: Help with retrieving data from SQL with server side PHP-Script (Async Token)
            snowscreen Level 1
            thanks for the quick answer run,ryan!
            Before posting, I had naturally numbered the trace statements. (now I see, that it would have been better to display that too )
            In fact it is this order:
                                       trace(uidCol); // 3th output
                               trace(uidCol); // 1th output
                      trace(uidCol); // 5th output - empty
                  trace(uidCol); // 4th output -empty
                  return temp // also 4th -empty
            So I don't understand why the data "gets lost", or how to solve this problem...
            please provide further help if you can
            EDIT: Trying to cut the function into small bits, having fist succes.. will be posting, when solved. But feel free to come with new, better ideas to make this whole thing possible!
            • 3. Re: Help with retrieving data from SQL with server side PHP-Script (Async Token)
              ntsiii Level 3
              First, in your handler, verify that you have the data you think.
              var xmlData:XML = XML(e.data);
              trace xmlData.toXMLString();
              • 4. Re: Help with retrieving data from SQL with server side PHP-Script (Async Token)
                snowscreen Level 1
                @ntssi: I assure you, the data is/was there in the returned xml
                But now i managed a way to get the right object "returned":
                private function getThis(searchString:String):void
                    var parameters:* =
                private function searchReqHandler(e:Object):void
                                if (e.isError)
                                else
                               search = new Event("se"+friendCount);
                               dispatchEvent(search);   //dispatching a unique event in order to get the right result when running getThis() in a loop
                LESSONs LEARNED
                1# Don't store your result in a too "local" variable when you're dependant on event handlers
                2# A way to establish a straight data returning in event-driven xmlrequests is to dispatch unique events, assuring that the data lands where it belongs.
                3# Don't nest your handlers(?)
                thanks for all your help, snowscreen
