4 Replies Latest reply on Apr 22, 2009 8:29 AM by Mylenium
    error in exporting photoshop file
    magiegabel
      We have several copies of After Effects being used in the office.  Both myself and another user have encountered a problem saving as photoshop layers.  It gets 87% or so into it and then gives the error; "error in exporting photoshop file" in the info window.  Any thoughts?
        • 1. Re: error in exporting photoshop file
          TimeRemapper Level 4
          What's going on in the comp that you're trying to export?
          Lots of precomps (nested comps only go back 5 steps as layer groups)? Effects? Is it a complex 3D composition?
          Can you post some more info about your setup?
          • 2. Re: error in exporting photoshop file
            magiegabel Level 1
            My setup does have a couple of precomps, lights and a lot of solids set in 3d space.  My coworker's comp had none of these.  His was a simple 2d animation.  I systematicly went through the layers that I though might be problematic and deleted them.  I got mine to work by deleting a null layer that had several expression controls on it that linked to various solids.  I got my co-workers to work by putting the project on a third machine and it came out fine. I've never had a problem with this until CS4.  Are there know issues with certain filters, 3d layers, etc.? Anyhow, Thanks for responding so quickly, but I got it worked out.
            • 3. Re: error in exporting photoshop file
              Right on. Glad you got it worked out.
              I could see how expressions might cause things to go wonky, but aside from that, I'm not sure.
              I really haven't used that feature in CS4 yet (although, I have used it many times in CS3).
              Is there version parity between Photoshop and AE (both CS4)?
              I'm not even sure if that matters. Maybe someone with a better idea of what's going on under the hood can chime in.
              • 4. Re: error in exporting photoshop file
                I don't think expressions should have any influence on teh matter. They are just another way of formulating an animation stream value just like keyframes. Icould think of a few things:
                - The new pixel aspect ratio handling in CS4. Due to the conversion, something may happen to the source footages.
                - Layer styles. this may cause a "cyclic use" of the Photoshop engine. Some of that stuff has changed quite a bit for CS4 to accomodate Ps Live 3D and teh new adjustment layer model.
                - Hardware accelerated effects. CS4 passes through OpenGL acceleration through all comps. Using an effect that uses it and happens to think it doesn#t need to fall back into software only mode, may cause a hiccup.
                - MediaCore. Similar to the previous, it uses hardware acceleration and may show weird behaviors, varying solely based on differences in graphics cards.
                In particular for the last two points I would think it is what makes the difference between your systems. One of them has not enough juice on OpenGL, so it's "safe". I'd definitely investigate along those lines.
                Mylenium
