9 Replies Latest reply on Oct 3, 2011 8:46 PM by Mainmanian
    Drag/Drop inside SWFLoader not working
    Brent Lamborn Level 2
      I've got a Flex application that loads a secondary Flex app via SWFLoader. The secondary app uses drag/drop operations to rearrange components, delete them etc.  The secondary app works perfectly while it is running by itself (eg. not 'embedded' via SWFLoader into the main app).
      Once I load it into the main application using a SWFLoader drag/drop operations no longer work correctly. All other events seems to work fine. It is only drag/drop that don't always work right.
      Is there something I am missing that would cause this issue? I'm thinking there may be a property I need to set on the SWFLoader. Hopefully someone can help.
