9 Replies Latest reply on Apr 23, 2009 2:09 PM by Michael Borbor
    Using an Object to get datagrid record properties? (update record)
    EvolvedDSM Level 2
      I have a datagrid that uses a set of data gathered from a remoteObject CFC.  The datagrid populates the result of the remoteObject method.  I then need the ability to edit records within the datagrid.  I have created a form that binds it's fields to the record properties of the selected item in the datagrid. So when a user clicks a record from the datagrid, the form fields populate with the appropriate data.  At this point, if they need to change any of the values, they can type their corrections.  There's a submit button that calls the update function updateRecord().  From here I'd like to stick all the values from the fields into an Object that has the structure of my data.  This is where I'm stuck.
      private function updateRecord(){
           var objNew:Object = new Object; // I want to store my updated values here
           var objOld:Object = new Object; // current values from the datagrid are stored here
           objNew = datagrid.selectedItem; // attempting to store and structure the values of the record from the datagrid
           objNew.firstName = firstNameInput.text; // firstName is a column of my data set
           objNew.lastName = lastNameInput.text; // lastName is also a column of my data set
           objOld = datagrid.selectedItem; // attempting to store the structure and values of the record from the datagrid
           remoteObject.update(objOld, objNew); // method that grabs the old object and new object and updates the record in the database
      At this point I would assume that when I set my objNew Object to datagrid.selectedItem, it contains both the structure of the record as well as it's values.  But when I update the record, it fails because the structure is not what the CFC is expecting (it checks the structure against a valueObject that contains the properties and data types of the record).
      So how can I get an object to take on the structure of my data and then modify the individual properties of the object so I can make changes to my record?
        • 1. Re: Using an Object to get datagrid record properties? (update record)
          Michael Borbor Level 4
          Hi there I think that what you need to do is not declare objNew as an object but as the dto or vo that is use to pass data and get data fro CF
          • 2. Re: Using an Object to get datagrid record properties? (update record)
            EvolvedDSM Level 2
            Well, I have tried using the VO and that works fine.  The problem is that not all data properties are available to edit via the form fields, so if I use the VO, I have to specify every property in my function even if they aren't being edited.
            For example, lets set my data contains a firstName, lastName, email, and phone property (or column in the db table).  I do not want the email and phone to be upated, only the firstName and lastName properties.  Yet in my function, for the VO to work, I would have to do this...
            myVO = new valueObject; // valueObject.as contains the data structure
            myVO.firstName = firstNameInput.text;
            myVO.lastName = lastNameInput.text;
            myVO.email = datagrid.selectedItem.email;
            myVO.phone = datagrid.selectedItem.phone;
            The reason I have to do this is because the VO will submit null/blank values as default if I do not specify other data to those properties (in this case email and phone).  If I exclude email and phone from myVO above, it will delete any value I might have had previously when the remoteObject method updates with my given data.
            I oringally thought I could do myVO = datagrid.selectedItem, however it will not accept this because my type valueObject is not of type Object (which datagrid.selectedItem is an Object).
            So I need a way to first populate an object or a valueObject with the data of datagrid.selectedItem.  That way I don't have to include unnecessary properties like email and phone if they will never change.  And then I can just set the properties I do want to change.
            Ideally something like...
            myVO = datagrid.selecteditem;
            and now email and phone properties are already populated because they took on whatever values were in datagrid.selectedItem.
            So, I need some help figuring this out.
            >>> Michael Borbor <forums@adobe.com> 4/22/2009 11:36 AM >>>
            • 3. Re: Using an Object to get datagrid record properties? (update record)
              Did you try casting your dg selectedItem to your VO?
              Sincerely,
              Michael
              do this...
              >>>> Michael Borbor <mailto:forums@adobe.com> 4/22/2009 11:36 AM >>>
              fro CF
              • 4. Re: Using an Object to get datagrid record properties? (update record)
                EvolvedDSM Level 2
                Yes I have but it fails.  It will only work if I set all the properties
                of the VO to either the form field or to datagrid.selectedItem.property,
                which if I'm doing it this way, I don't even need to set it to the
                selectedItem because I'm manually setting my data now.  This is what I'm
                trying to avoid.  I shouldn't have to type out every property.
                I tried
                myVO = datagrid.selectedItem as valueObject;
                This seems to hold a value, but the update fails unless I give each
                property of the VO a value.  ie, having to set phone and email =
                datagrid.selectedItem.phone/email.
                Could it be that the data type changes?  For instance, one of the
                columns/properties of the data set is of date data type in my VO, but
                the data type from the datagrid might be changing the date to a string?
                I have a feeling that the tie-up is probably due to the date data type.
                Ugh, I hate dealing with dates.
                >>> Michael Borbor <forums@adobe.com> 4/22/2009 12:10 PM >>>
                Sincerely,
                Michael
                El 22/04/2009, a las 10:46, EvolvedDSM <mailto:forums@adobe.com>
                do this...
                structure
                >>>> Michael Borbor <mailto:mailto:forums@adobe.com> 4/22/2009 11:36 AM
                fro CF
                • 5. Re: Using an Object to get datagrid record properties? (update record)
                  Maybe I'll try to reproduce this later and tell you my findings. Did
                  you try in this way myobj:myVo=new myVo(dg.selectedItem)
                  Sincerely,
                  Michael
                  properties
                  I'm
                  I tried
                  string?
                  type.
                  >>>> Michael Borbor <mailto:forums@adobe.com> 4/22/2009 12:10 PM >>>
                  Sincerely,
                  Michael
                  >> do this...
                  structure
                  >>>>> Michael Borbor <mailto:mailto:mailto:forums@adobe.com> 4/22/2009
                  >>>>> 11:36 AM
                  >> fro CF
                  • 6. Re: Using an Object to get datagrid record properties? (update record)
                    EvolvedDSM Level 2
                    Ya I had tried that and it returned a problem within Flex Builder saying that it expected a value of no more than 0.
                    I'm going to cfmail a cfdump of my object when it gets sent to the CFC.
                    Also, if it helps, these are the CFC's that are generated with the CF wizard in flex builder.  So if you want a reference and you have ColdFusion with a datasource, check out the update() function.  Previously I had used this same way of udpating data in my last app, but I was also setting every property of the VO manually... so I never ran into this issue.
                    I'll see what the dump says
                    This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain private, confidential, and/or privileged information. Any unauthorized review, use, disclosure, or distribution is prohibited. If you are not the intended recipient, employee, or agent responsible for delivering this message, please contact the sender by reply e-mail and destroy all copies of the original e-mail message.
                    • 7. Re: Using an Object to get datagrid record properties? (update record)
                      EvolvedDSM Level 2
                      I thought emailing my responses would be a convenient way to do things, but then I remembered, "ITS EMAIL" and everything previously in the email gets posted here.
                      Perhaps if we continue using email, we clean up old messages so we don't get lengthy posts.
                      Would be nice if Adobe would handle parsing out >>>>  so old messages do not get posted.
                      • 8. Re: Using an Object to get datagrid record properties? (update record)
                        EvolvedDSM Level 2
                        Issue is with filterFunction and date value.
                        See this thread for a continuation to my issue.
                        http://forums.adobe.com/thread/423386
                        • 9. Re: Using an Object to get datagrid record properties? (update record)
                          Hi there, I was playing with the RO and casting stuff and this casting works for me:
                          myData=myVO(myDG.selectedItem)
                          Where myData is a var of type myVO, and myVO is a value object, so I can modify any properties as long as I don't play with the date field I can update the registry without a problem.
