5 Replies Latest reply on Apr 23, 2009 10:14 AM by jmmorgan
    Error converting CFML arguments to Java classes for web service invocation.
    kenji776
      Hello all.
      I am working on writting a small application that will use a web service that is provided by our IVR (Angel.com). I am able to login, however when I attempt to do anything with complex objects, I get the error stated in the title.
      It seems to be having a problem with the array, because when I remove it, or turn it into a simple string, i get errors about the function not being found. I am fairly new to web services, and especially dealing with complex data types, so any help would be much appreciated.
      You can see my testing page at
      http://webservices.fpitesters.com/AngelCalls.cfm
      The WSDL I am using can be found at
      http://www.angel.com/outbound/wsdl/OutboundCallService.wsdl
      Here is sample code that does what I want it to do in Java / Apache Axis
      http://www.socialtext.net/ivrwiki/index.cgi?java_sample_code
      Here is a description of the function I am having problems with
      http://www.socialtext.net/ivrwiki/index.cgi?placecall
      And attached is my code.
           <cfset email = "xxxxxxxxxxxxxxxxxx">
           <cfset pin = "xxxxxxxxxxxx">
           <cfinvoke webservice="http://www.angel.com/outbound/wsdl/OutboundCallService.wsdl" method="login" returnvariable="login">
                <cfinvokeargument name="email" value="#email#"/>
                <cfinvokeargument name="pin" value="#pin#"/>
           </cfinvoke>
           <cfdump var="#login#">
           <cfset Token = login.getToken()>
           <cfdump var="#token#">
           <cfset CallItem.maxWaitTime = 100>
           <cfset CallItem.phoneNumbers[1] = "7632344306">
           <cfset CallItem.siteNumber = 100041>
           <cfinvoke webservice="http://www.angel.com/outbound/wsdl/OutboundCallService.wsdl" method="placeCall" returnvariable="call">
                <cfinvokeargument name="Token" value="#Token#"/>
                <cfinvokeargument name="CallItem" value="#CallItem#"/>
           </cfinvoke>
           <cfdump var="#call#">
        • 1. Re: Error converting CFML arguments to Java classes for web service invocation.
          jmmorgan Level 1
          If you are not initializing phoneNumbers as an array before setting
          it will be passed as a struct with a key of 1.  This could cause your argument conversion error.
          So:
          Will result in
          struct
          MAXWAITTIME100
          PHONENUMBERS
          struct
          17632344306
          SITENUMBER100041
          <cfset CallItem = StructNew() > <!--- For Good Measure --->
          <cfset CallItem.maxWaitTime = 100 >
          <cfset CallItem.phoneNumbers = arrayNew(1) /> <!--- Required --->
          Will result in
          struct
          MAXWAITTIME100
          PHONENUMBERS
          array
          17632344306
          SITENUMBER100041
          - Jason Morgan
          • 2. Re: Error converting CFML arguments to Java classes for web service invocation.
            kenji776 Level 1
            Thank you so much for your very helpful answer, that did the trick. It seems odd to me that the array is a struct unless otherwise declaired, but hey, live and learn. Again thank you, I really appreciate it.
            • 3. Re: Error converting CFML arguments to Java classes for web service invocation.
              kenji776 Level 1
              Since we are on the subject, do you have any idea what this error means?
              The getOutboundCallGUID method was not found.
              Either there are no methods with the specified method name and argument types, or the getOutboundCallGUID method is overloaded with argument types that ColdFusion cannot decipher reliably. ColdFusion found 0 methods that matched the provided arguments. If this is a Java object and you verified that the method exists, you may need to use the javacast function to reduce ambiguity.
              The call that you helped me put together returns a method with that name (like how login returns a method called getToken() which i called with
              <cfset Token = login.getToken()> ) however, when I attempt to call it in the same fashion ex:
              <cfset Guid = placecall.getOutboundCallGUID()>
              I get the error above. Again, I'm sure this is probably simple stuff for you web service masters, I am just kinda breaking into it however, and some of these errors are fairly cryptic for a newbie like me. This is my full source now.
                   <cfset pin = "xxxxxxxxx">
                   </cfinvoke>
                   <cfinvoke webservice="http://www.angel.com/outbound/wsdl/OutboundCallService.wsdl" method="placeCall" returnvariable="placecall">
                   </cfinvoke>
                   <cfdump var="#placecall#">
                      <!--- This is where the error occures now---->
                   <cfdump var="#Guid#">
              • 4. Re: Error converting CFML arguments to Java classes for web service invocation.
                jmmorgan Level 1
                Glad I could help.
                The result of PlaceCall is an Array.  So your code needs to be :
                <cfset Guid = placecall[1].getOutboundCallGUID()>
                This assumes you are only interested in the first element of course.
                • 5. Re: Error converting CFML arguments to Java classes for web service invocation.
                  jmmorgan Level 1
                  I hope this helps.
                  kenji776 wrote:
                  ... It seems odd to me that the array is a struct unless otherwise declaired ...
                  CF does not know if you are referencing an array or a struct.  It can refer to structures with the same notation as you would refer to an array.  IE.
                  <cfset CallItem.phoneNumbers[1] = "7632344306" >
                  <cfset CallItem.siteNumber = 100041 >
                  is the same as
                  <cfset CallItem["maxWaitTime"] = 100 >
                  <cfset CallItem["phoneNumbers"][1] = "7632344306" >
                  <cfset CallItem["siteNumber"] = 100041 >
                  So there is know way for CF to know that you are referencing an array vs a structure.  It could make a guess and say that since the index is numeric
                  create an array but that is not any more valid than the way it does it.
