4 Replies Latest reply on Apr 23, 2009 5:30 PM by ntsiii
    Get Results From RemoteObject
    Miggl Level 1
      Not sure what's gotten into me today... feel like I'm loosing it.
      I'm getting a list of users back from a RemoteObject method call. I can't seem to remember how to parse them out. Is this the appropriate method?
      private function loadUsersByGroupHandler(event:ResultEvent):void
           try
                this._assignedUsers = event.result as ArrayCollection;
           catch (error:FaultEvent)
                this.parentDocument.faultHandle(event);
      The problem here is that when I do this, I am unable to inspect the resulting ArrayCollection for length or anything else, as the following fails (no error is thrown, but also no alert is shown):
           try
                     Alert.show(ArrayCollection(event.result).length.toString());
        • 1. Re: Get Results From RemoteObject
          Michael Borbor Level 4
          Try this._myAC= new ArrayCollection( event.result as Array)
          Sincerely,
          Michael
          appropriate method?
               try
                    this.parentDocument .faultHandle(event);
               try
          • 2. Re: Get Results From RemoteObject
            Miggl Level 1
            That would fix it! Thanks.
            Can anyone explain why I have to ppass in an Array into an ArrayObject? I was under the impression that Arrays and ArrayObjects were essentially equal, other than that ArrayCollections can update Dynamically.
            Mike
            • 3. Re: Get Results From RemoteObject
              Not really an array expects a generic object, while the AC expects an
              Array take a look at the docs to understand more about this.
              Sincerely,
              Michael
              Dynamically.
              Mike
              • 4. Re: Get Results From RemoteObject
                ntsiii Level 3
                "...Arrays and ArrayObjects[sic] were essentially equal..."  No, not at all.  ArrayCollection has much more functionality than Array, including a full API.
                Further, on you original issue, the "as" operator requires that the reference on the left side contains an object of the type on the right of the operator. While it might be possible that the remote call's event.data reference contains a Flex collection, it is not very likely.  ObjUtil has some methods for inspecting objects.
                Tracy Spratt
