12 Replies Latest reply on Apr 22, 2009 8:16 PM by Flex harUI
    Composite labelField attribute?
    Miggl
      I would like to specify a composite labelField attribute (on a List control for example). The following works brilliantly, displaying a single field:
      <mx:List
           id="l_selected"
           dataProvider="{this._rightItems}"
           labelField="first_name"
           height="100%"
           width="100%"
      Unfortunately, when I try the following, it failes:
      <mx:List
           id="l_selected"
           labelField="first_name last_name"
           height="100%"
           width="100%"
        • 1. Re: Composite labelField attribute?
          Gregory Lafrance Level 6
          Use labelFunction and concatenate as desired in the function.
          • 2. Re: Composite labelField attribute?
            Miggl Level 1
            I have been playing around with that, since my original post, but have yet been unsuccessful (see the following).
            Let me add a twist to the problem:
            I have a custom composite component. I would like to set the labelFunction dynamically outside of the component, allowing the consumer to define their own functions.
            My initial approach was to create a getter and setter for the function, but I have not been able to make that work.
            <mx:Script>
            <![CDATA[
                 private function showUserName(user:UserVO):String
                      return user.first_name + " " + user.last_name;
            </mx:Script>
            <myComponent
                 id="customComponent"
                 labelFunction="{showUserName}"
            Then within the component, I have declared the following:
            <mx:Script>
            <![CDATA[
                 [Bindable]
                 private var _labelFunction     :Function;
                 public function get labelFunction():Function
                      return this._labelFunction;
                 public function set labelFunction(value:Function):void
                      this._labelFunction = value;
            </mx:Script>
            <mx:List
                 id="l_available"
                 labelFunction="{this._labelFunction}"
                 height="100%"
                 width="100%"
            • 3. Re: Composite labelField attribute?
              Flex harUI Adobe Employee
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              Blog: http://blogs.adobe.com/aharui
              • 4. Re: Composite labelField attribute?
                Miggl Level 1
                Not sure I understand how a reference to your blog helps my situation. Please be a bit more specific if you actually have a solution, etc.
                • 5. Re: Composite labelField attribute?
                  -Hob Level 1
                  Currently your private var is marked [Bindable].  Try moving the [Bindable] tag to your public getter/setter and binding to that instead:
                  <mx:Script>
                  <![CDATA[
                       [Bindable]
                  </mx:Script>
                  <mx:List
                       id="l_available"
                       labelFunction="{this.labelFunction}"
                       height="100%"
                       width="100%"
                  • 6. Re: Composite labelField attribute?
                    The "consumer" shouldn't need to use binding at all.
                    -Hob's code will be more efficient, but it should have worked either way.
                    Alex Harui
                    Flex SDK Developer
                    Adobe Systems Inc.
                    • 7. Re: Composite labelField attribute?
                      Miggl Level 1
                      Thanks Hob and Alex,
                      I still haven't been able to get your solution to work. So I thought I'd go back to basics and start from within the component by defining the labelFunction within the component.
                      Unfortunately that doesn't seem to work either. Check out the following:
                           <mx:Script>
                                <![CDATA[
                                     private function showUserName(item:Object):String
                                          //Alert.show("Test");
                                          //var user:UserVO = item as UserVO;
                                          return "test";
                           </mx:Script>
                           <mx:List
                                id="l_available"
                                labelFunction="showUserName"
                                height="100%"
                                width="100%"
                      I don't know why this won't run. Even if I just put an alert in the showUsername function, it never seems to get called.
                      • 8. Re: Composite labelField attribute?
                        Miggl Level 1
                        So, I have been able to get my local function working within the component. (I was applying it to the incorrect component within my custom component, so I wasn't seeing the results. Duh! )
                        Now I'll see if I can get it working by passing in the function as you guys described above.
                        Thanks!
                        -Mike
                        • 9. Re: Composite labelField attribute?
                          Miggl Level 1
                          After a bit of struggling, I was finally able to get it to work. Here's what I ended up with:
                          Consuming App:
                               <mx:Script>
                                    <![CDATA[
                                         private var _showUserName     :Function                = function(item:Object):String
                                              return item.first_name + " " + item.last_name;
                               </mx:Script>
                               <composite:myCustomControl
                                    labelFunction="{_showUserName}"
                                    paddingTop="5"
                                    paddingRight="5"
                                    paddingBottom="5"
                                    paddingLeft="5"
                          And then in the custom composite control:
                               <mx:Script>
                                    <![CDATA[
                                         [Bindable]
                                                  [Bindable]
                                         private function set labelFunction(value:Function):void
                               </mx:Script>
                               <mx:List
                                    labelFunction="{this._labelFunction()}"
                                    height="100%"
                                    width="100%"
                          I choose not to use the getter method within the object, just because I would consider using a accessor method from within a class bad practice (personal feeling). I'll open another thread to discuss this, as I would be interested to see what is considered best practice in AS3.
                          Thanks!
                          • 10. Re: Composite labelField attribute?
                            Well, I'm glad you got it working, but I don't think it should have taken all of that.
                            Alex Harui
                            Flex SDK Developer
                            Adobe Systems Inc.
                            • 11. Re: Composite labelField attribute?
                              Miggl Level 1
                              What would you have in mind? I'd be eager to see a sleeker way of accomplishing this (not at all saying it can't be done, I just don't know, since I'm still new at FLEX).
                              Thanks!
                              • 12. Re: Composite labelField attribute?
                                In theory:
                                Consuming App:  (No {} around labelFunction assignment
                                     <mx:Script>
                                          <![CDATA[
                                             & nbsp; private var _showUserName     :Function              & nbsp; = function(item:Object):String
                                             & nbsp; {
                                             & nbsp;      return item.first_name + " " + item.last_name;
                                             & nbsp; }
                                     </mx:Script>
                                          labelFunction="_sh owUserName"
                                          paddingTop="5"
                                          paddingRight="5"
                                          paddingBottom="5"
                                          paddingLeft="5"
                                And then in the custom composite control: (A single var and appropriate changes to labelFunction assignment
                                     <mx:Script>
                                          <![CDATA[
                                             & nbsp;
                                             & nbsp; public var labelFunction     :Function;
                                     </mx:Script>
                                     <mx:List
                                          height="100%"
                                          width="100%"
                                Alex Harui
                                Flex SDK Developer
                                Adobe Systems Inc.
