2 Replies Latest reply on Apr 22, 2009 7:16 PM by Jeff Bellune
    lower third super "bug"?
    kirm99
      Don't know if there's a solution or if it's "just one of those things"...
      But I started a project in PPro CS2, with lower third graphics created in AE with an alpha channel so they're self-keying. I had them fade in at the same time a directional blur effect was fading out.
      I recently updated to PPro CS4. When I opened this project in CS4, the lower third fades in okay, but at the point the blur reaches 0, the entire graphic jumps down a few lines.
      I tried using a different type of blur, but it still jumps.
      I tried reinserting the lower third and adding the fade in and blur fresh - but it still happens. To make sure it wasn't just the monitoring, I exported the section and the jump is definitely there.
      It works okay without the blur, so I may have to settle for that.
      Any suggestions? I just thought - I'll try reimporting the graphic, and also double check the alpha channels settings are correct...
