1 Reply Latest reply on Aug 1, 2008 2:33 AM by Hariselvann
    The link on the FLASh is still not working
    blogfor
      I created a FLASH hoping that the link would work. It works when it's all a FLASH page, but when embedded on to an HTML page it stops working. It has nothing to do with my browser setting I think because when I visit other sites, I can click on their FLASH links and they work fine.
      Will somebody please check my page and tell me what went wrong on my HTML page?
      Here is the link to the FLASH page where the Order Now button works
      http://site.jesseworks.com/jamerica/8821hoodedsweats.swf
      Here is the link to the HTML page where I embedded the code below. You will notice on the page that the Order Now button no longer works. It changes to a HAND when you roll over it, but it won't take you to the item's page like the link above.
      http://www.jesseworks.com
      I embedded the link below to the HTML page. This is the page where the Order Now button is not working. It will not take you to the item's page.
        • 1. Re: The link on the FLASh is still not working
          Hariselvann
          Hi blogfor
          If both j-america-hooded-sweatshirt.html and 8821hoodedsweats.swf files are in Same directory then no problem it will work.
          suppose it is different directory or in different server then you must change the Local PlayBack Security to Access network only . It is in Publish settings.
          If you give your mail id then i will send you the fla, swf and html files.
