4 Replies Latest reply on Apr 24, 2009 5:34 AM by m_hartnett
    Using Item Renderers in Data Grid Controls
      I created a Flex Project with a Data Grid Control. While adding a Column to the data grid, i wanted to add a Link Button as an editor to the column so i could perform some operation on the click.
      I created a Component file for item rendering with the component as Link Button. All the things run fine but i am not able to display the Label of the Link Button, thus the column with link button remain blank. Even i am able to perform the operation on the click but the text is not displayed.
      I tried searching for some solutions but could not find any solution after implementating many.
      I am attaching the Source MXML files so that you can check if i have coded correclty.
      Let me know if you have some solution to this problem.
      Thanks and Kind Regards,
      Gaurav.
        • 1. Re: Using Item Renderers in Data Grid Controls
          m_hartnett Level 3
          You should cut and paste your code in the question.
          For some reason all the attachments are 'queued' and cannot be viewed.
          • 2. Re: Using Item Renderers in Data Grid Controls
            Gregory Lafrance Level 6
            This code might provide some insight:
            <?xml version="1.0"?>
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:ArrayCollection id="ac">
                <mx:Object>
                  <mx:Site>Google</mx:Site>
                  <mx:MyLink>http://www.google.com</mx:MyLink>
                </mx:Object>
                <mx:Object>
                  <mx:Site>Yahoo</mx:Site>
                  <mx:MyLink>http://www.yahoo.com</mx:MyLink>
                </mx:Object>
                <mx:Object>
                  <mx:Site>Adobe</mx:Site>
                  <mx:MyLink>http://www.adobe.com</mx:MyLink>
                </mx:Object>
              </mx:ArrayCollection>
              <mx:DataGrid dataProvider="{ac}">
                <mx:columns>
                  <mx:DataGridColumn dataField="Site" width="100"/>
                  <mx:DataGridColumn dataField="MyLink" width="200">
                    <mx:itemRenderer>
                      <mx:Component>
                        <mx:LinkButton label="{data.MyLink}" click="navigateToURL(new URLRequest(data.MyLink), '_blank')"/>
                      </mx:Component>
                    </mx:itemRenderer>
                  </mx:DataGridColumn>
                </mx:columns>
              </mx:DataGrid>
            </mx:Application>
            • 3. Re: Using Item Renderers in Data Grid Controls
              Level 1
              The Code for Main MXML File is
              <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical
              width="
              100%" height="100%" initialize="initApp()" backgroundColor="#eaf1f6
              backgroundGradientAlphas="
              1.0,1.0"
              <mx:Script>
              <![CDATA[
              import
              mx.controls.dataGridClasses.DataGridListData;
              import
              mx.controls.LinkButton;
              import
              mx.rpc.soap.SOAPFault;
              import
              sap.FlashIsland;
              import
              mx.collections.ArrayCollection;
              import
              mx.graphics.IFill;
              import
              mx.graphics.SolidColor;
              import
              mx.controls.Alert;
              import
              mx.core.ClassFactory;
              Bindable
              public var
              dataSource:ArrayCollection;
              Bindable
              public var
              col1:String;
              Bindable
              public var
              col2:String;
              Bindable
              public var
              col3:String;
              Bindable
              public var
              riskTitle:String;
              Bindable
              public var
              orgunitTitle:String;
              Bindable
              public var
              activityTitle:String;
              Bindable
              public var
              linkButton:IFactory;
              public function initApp():
              void
              FlashIsland.register(
              this
              FlashIsland.addEventListener(FlashIsland.EVENT_END_UPDATE_DATASOURCES, updateDone);
              public function updateDone():
              void
              Alert.show(dataSource.length.toString());
              public function filterOrgunit():
              void
              FlashIsland.storeProperty(
              this,"orgunitTitle"
              ,orgunit.text);
              FlashIsland.fireEvent(
              this,"filterOrgunit"
              </mx:Script>
              <mx:Form
              <mx:FormItem label="Organization" fontWeight="bold"
              <mx:TextInput id="orgunit" text="{orgunitTitle}" change="filterOrgunit()"
              <mx:Button id="click" label="Filter" click="filterOrgunit()"
              </mx:FormItem>
              </mx:Form>
              <mx:DataGrid width="803" height="198" id="table1" dataProvider="{dataSource}"
              <mx:columns>
              <mx:DataGridColumn headerText="Risk Id" dataField="riskid" visible="false"
              <mx:DataGridColumn headerText="Risk Title" dataField="{col1}" fontWeight="bold
              itemRenderer="
              DGListRenderer"
              <mx:DataGridColumn headerText="Organization" dataField="{col2}"
              <mx:DataGridColumn headerText="Activity" dataField="{col3}"
              </mx:columns>
              </mx:DataGrid>
              </mx:Application>
              And for the renderer file DGListRenderer is
              <mx:LinkButton
              " click="clickRisk()"
              label="
              {data.col1}"
              <mx:Script
              <![CDATA[
              import
              mx.core.Application;
              import
              import
              sap.FlashIsland;
              import
              public function clickRisk():
              void
              FlashIsland.setLeadSelection(
              this
              , Application.application.dataSource, Application.application.table1.selectedItem);
              this, 'clickRisk'
              Application.application.table1.selectedItem.setFocus();
              </mx:Script>
              </mx:LinkButton>
              • 4. Re: Using Item Renderers in Data Grid Controls
                m_hartnett Level 3
                This code looks fine but I don't see where the dataProvider (dataSource) is built.
                Can you show what is in the AC and how it is created?
