8 Replies Latest reply on Apr 24, 2009 9:03 AM by m_hartnett
    how to swap the position of two objects?
    ningyuanma
      I have four self made componensts that I imported them into my main mxml file
      and placed each on four corners.
      What I want to achieve is to drag each component onto others then swap their position.
      For example, comp A is dragged over comp B, when this is detected, swap the position of A and B.
      But at the moment it doesn't seem to work properly. I could not figure out what's wrong with my code. Could any one help me achieve that?
      Many thanks to any who could give me a hand!
      *********This is one of my component***********
      *********All other three components are made the same way, except each source of image file is different******************
      <mx:Box xmlns:mx="http://www.adobe.com/2006/mxml" width="42" height="42">
          <mx:Image source="Images/air.png"/>
      </mx:Box>
      *********This is my mxml that calls my components***********
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:comp="Comp.*" creationComplete = "onInit()">
          <mx:Script>
              <![CDATA[
                  import mx.containers.Box;
                  import Comp.Icon_illustrator;
                  import Comp.Icon_air;
                  import Comp.Icon_flash;
                  import Comp.Icon_flex;
                  private var i_1:Icon_air; //1
                  private var i_2:Icon_flash; //2
                  private var i_3:Icon_flex; //3
                  private var i_4:Icon_illustrator; //4
                  private var origX:Number;
                  private var origY:Number;
                  private var startObj:String;
                  private var icons:Array;
                  private var h_1:Box;
                  private var h_2:Box;
                  private var h_3:Box;
                  private var h_4:Box;
                  private function onInit():void{
                      //initialise all icons
                      i_1 = new Icon_air();
                      i_2 = new Icon_flash();
                      i_3 = new Icon_flex();
                      i_4 = new Icon_illustrator();
                      i_1.name = "i_1";
                      i_2.name = "i_2";
                      i_3.name = "i_3";
                      i_4.name = "i_4";
                      //populate icon
                      showArea.addChild(i_1);
                      showArea.addChild(i_2);
                      showArea.addChild(i_3);
                      showArea.addChild(i_4);
                      //set x position
                      i_1.x = 100;
                      i_2.x = 200;
                      i_3.x = 100;
                      i_4.x = 0;
                      //set y position
                      i_1.y = 0;
                      i_2.y = 100;
                      i_3.y = 200;
                      i_4.y = 100;
                      icons = [i_1, i_2, i_3, i_4];
                      //addEventListeners
                      for(var i:int=0; i<icons.length; i++){
                          icons[i].addEventListener(MouseEvent.MOUSE_DOWN, moveMe);
                          icons[i].addEventListener(MouseEvent.MOUSE_UP, stopDragMe);
                  }//end of onInit
                  private function moveMe(e:MouseEvent):void{
                      e.currentTarget.startDrag();
                      showArea.setChildIndex(DisplayObject(e.currentTarget), 0);
                      origX = e.currentTarget.x;
                      origY = e.currentTarget.y;
                      startObj = e.currentTarget.name;
                  private function stopDragMe(e:MouseEvent):void{
                      if(this[startObj].hitTestObject(icons[1])){
                          trace("hit 2");
                          this[startObj].x = i_2.x;
                          this[startObj].y = i_2.y;
                          i_2.x = origX;
                          i_2.y = origY;
                      }else if(this[startObj].hitTestObject(icons[0])){
                          trace("hit 1");
                          this[startObj].x = i_1.x;
                          this[startObj].y = i_1.y;
                          i_1.x = origX;
                          i_1.y = origY;
                      }else{
                          trace("hit others");
                          this[startObj].x = origX;
                          this[startObj].y = origY;
                      e.currentTarget.stopDrag();
                  }//end of stopDragMe
          </mx:Script>
          <mx:Panel id="showArea" width="400" height="300" layout="absolute" backgroundColor="0x999999"/>
      </mx:WindowedApplication>
        • 1. Re: how to swap the position of two objects?
          m_hartnett Level 3
          Here is a sample of swaping two objects in Flex (not Air)   I believe it is the same.  Take a look at the way the x and y coords are swapped using the dragInitator and the currentTarget object in the dragDropHandler.
          Hope this helps
          <mx:Application
          xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:local="*">
          <mx:Script>
          <![CDATA[
          import mx.core.UIComponent;
          import mx.managers.DragManager;
          import mx.core.DragSource;
          import mx.events.DragEvent;
          private var dragProxy:Box= new Box();
          public function dragDropHandler(e:DragEvent): void {
          //These variables are the x and y coords of the objects
          //the e.dragInitator is the object being dragged
          //the e.currentTarget is the object being dropped on
          //First save the x and y coords of each of the objects
          var xdi:int = e.dragInitiator.x;
          var ydi:int = e.dragInitiator.y;
          var xct:int = e.currentTarget.x;
          var yct:int = e.currentTarget.y;
          //now switch them around.
          e.dragInitiator.x = xct;
          e.dragInitiator.y = yct;
          e.currentTarget.x = xdi;
          e.currentTarget.y = ydi;
          public function dragEnterHandler(event:DragEvent):void {
          DragManager.acceptDragDrop(UIComponent(event.target));
          public function mouseMoveHandler(event:MouseEvent):void {
          if(event.buttonDown == false) return;
          var dragInitiator:UIComponent = event.target as UIComponent;
          var dragSource:DragSource = new DragSource();
          dragProxy =
          new Box();
          dragProxy.width = dragInitiator.width;
          dragProxy.height = dragInitiator.height;
          dragProxy.setStyle(
          "borderStyle","solid")
          dragProxy.setStyle(
          "borderColor","0x000000")
          dragProxy.setStyle(
          "backgroundColor","0xc6c6c6");
          DragManager.doDrag(dragInitiator, dragSource, event, dragProxy,
          event.localX * -1, event.localY * -1, 1.00);
          </mx:Script>
          <mx:Canvas width="84" height="93" x="23" y="14"
          borderStyle="
          solid"
          borderColor="
          #030303"
          backgroundColor="
          #F83C3C"
          dragEnter="dragEnterHandler(event)"
          dragDrop="dragDropHandler(event)"
          mouseMove="mouseMoveHandler(event)"
          </mx:Canvas>
          <mx:Canvas width="84" height="93" x="223" y="14"
          borderStyle="
          solid"
          borderColor="
          #030303"
          backgroundColor="
          #C5F83C"
          </mx:Canvas>
          </mx:Application>
          • 2. Re: how to swap the position of two objects?
            ningyuanma Level 1
            Many thanks wingobaxter!
            What if I need the objects be created dynamiclly?
            say I have this component to be imported?
            </mx:Box>
            So far I still could not get things work under dynamic creation.
            • 3. Re: how to swap the position of two objects?
              ningyuanma Level 1
              Now I've tried to make it creating components dynamically, but I get an error in the last line of mouseMoveHandler
              DragManager.doDrag(dragInitiator, dragSource, event, dragProxy);
              And the error is
              TypeError: Error #1009: Cannot access a property or method of a null object reference.
              How could I resolve this problem?
                  <mx:Script>
                      <![CDATA[
                          private var dragProxy:Box;
                              i_1.name = "i_1";
                              i_2.name = "i_2";
                              i_3.name = "i_3";
                              i_4.name = "i_4";
                              //populate icon
                              //set x position
                              i_1.x = 100;
                              i_2.x = 200;
                              i_3.x = 100;
                              i_4.x = 0;
                              //set y position
                              i_1.y = 0;
                              i_2.y = 100;
                              i_3.y = 200;
                              i_4.y = 100;
                              //addEventListeners
                                  icons[i].width = 42;
                                  icons[i].height = 42;
                                  icons[i].addEventListener(DragEvent.DRAG_ENTER, dragEnterHandler);
                                  icons[i].addEventListener(DragEvent.DRAG_DROP, dragDropHandler);
                                  icons[i].addEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
                          }//end of onInit
                          // dragEnterHandler
                          private function dragEnterHandler(event:DragEvent):void{
                          // dragDropHandler
                          private function dragDropHandler(e:DragEvent):void{
                          // mouseMoveHandler
                          private function mouseMoveHandler(event:MouseEvent):void{
                              dragSource.addData(dragInitiator, "UIComponent");
                              dragProxy = new Box();
                              dragProxy.width = 42;
                              dragProxy.height = 42;
                              dragProxy.setStyle("borderStyle","solid")
                              dragProxy.setStyle("borderColor","0x898989")
                              dragProxy.setStyle("backgroundColor","0xdcdcdc");
                  </mx:Script>
              • 4. Re: how to swap the position of two objects?
                Michael Borbor Level 4
                This shows you how to create dynamic UI.
                <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" >
                     <mx:Script>
                          <![CDATA[
                               import mx.controls.TextArea;
                               import mx.containers.Canvas;
                               private function createTextAreas():void{
                                    for(var a:Number=1;a<5;a++){
                                         var canvas:Canvas=new Canvas();
                                         var textArea:TextArea=new TextArea();
                                         textArea.text="I'm a Text Area " + a.toString();
                                         myVBox.addChild(canvas);
                                         canvas.addChild(textArea);
                     </mx:Script>
                     <mx:VBox id="myVBox" />
                     <mx:Button click="createTextAreas()" label="Create text areas" />
                </mx:Application>
                • 5. Re: how to swap the position of two objects?
                  ningyuanma Level 1
                  Thanks, Michael Borbor!
                  I've made it creating components dynamically, but I get an error in the last line of mouseMoveHandler
                  And the error is
                      <mx:Script>
                          <![CDATA[
                                  i_1.name = "i_1";
                                  i_2.name = "i_2";
                                  i_3.name = "i_3";
                                  i_4.name = "i_4";
                                  //populate icon
                                  //set x position
                                  i_1.x = 100;
                                  i_2.x = 200;
                                  i_3.x = 100;
                                  i_4.x = 0;
                                  //set y position
                                  i_1.y = 0;
                                  i_2.y = 100;
                                  i_3.y = 200;
                                  i_4.y = 100;
                                  //addEventListeners
                              }//end of onInit
                              // dragEnterHandler
                              // dragDropHandler
                              // mouseMoveHandler
                      </mx:Script>
                  • 6. Re: how to swap the position of two objects?
                    You need to change this line:
                    to this:
                    var dragInitiator:UIComponent = event.currentTarget as UIComponent;
                    • 7. Re: how to swap the position of two objects?
                      ningyuanma Level 1
                      It works now!!! Thank you Michael Borbor
                      Could you explain a bit on what's the difference between
                      event.target
                      and
                      event.currentTarget
                      ? Because I don't really know when to use currentTarget and when to use target...
                      Many thanks!
                      • 8. Re: how to swap the position of two objects?
                        m_hartnett Level 3
                        Take a look at the api documentation for the Event object.  This has info on currentTarget and target.
                        http://livedocs.adobe.com/flex/3/langref/index.html
                        Also read up on the event process
                        http://livedocs.adobe.com/flex/3/html/help.html?content=events_02.html
                        These docs are great and provide a lot of information
