1 Reply Latest reply on Apr 23, 2009 6:04 AM by logeye
    Print Function
    tashmac Level 1
      Hi
      I am trying to create a print button and i just need some help with the action script.  Print (Target, type) is the function i know target is the name of the file i want to print but can someone tell me what type is for.
      Natasha
        • 1. Re: Print Function
          logeye Level 1
          I just learned how to do that.  The code in the actionScript help files were pretty stratght forward.  I use Flash 8 ActionScript2.
          Here's what I did.  This script is inserted on the main timeline  I made a movieclip button with _over, _up, _down, and _quit labels.  The resr is from the actionScript help text.
          stop();
          // for the movieclip acting as a button
          var printed:Boolean = false;
          printBtn.onRollOver = function() {
          printBtn.gotoAndStop("_over");
          printBtn.onRollOut = function() {
          if (!printed) {
            printBtn.gotoAndPlay("_quit");
          printBtn.onReleaseOutside = function() {
          if (!printed) {
          printBtn.onPress = function() {
          printBtn.gotoAndStop("_down");
          printBtn.onRelease = function() {
          printed = true;
          printBtn.gotoAndStop("_up");
          // create PrintJob object  // this starts the actionScript help text
          var my_pj:PrintJob = new PrintJob();
          // display print dialog box, but only initiate the print job
          // if start returns successfully.
          if (my_pj.start()) {
            // use a variable to track successful calls to addPage
            var pagesToPrint:Number = 0;
            // add specified area to print job
            // repeat once for each page to be printed
          // "page" is the name of the movieclip to print- use the quotes
            if (my_pj.addPage("page")) {
             pagesToPrint++;
            /*  if (my_pj.addPage([params])) {
            pagesToPrint++;
            pagesToPrint++;
            // send pages from the spooler to the printer, but only if one or more
            // calls to addPage() was successful. You should always check for successful
            // calls to start() and addPage() before calling send().
            if (pagesToPrint>0) {
             my_pj.send();
             // print page(s)
          // clean up
          delete my_pj;
          // delete object
          hope this helps.
