10 Replies Latest reply on Apr 23, 2009 12:14 PM by Lee Crockett
    Comparing a list with a query output
    Lee Crockett
      I may just be really tired, but I'm just not getting this.  What I'm trying to accomplish is to output a query, and as it's outputting, check a list to see if a value exists, and if so, change the class of a <li>
      I have two queries and am defining a list from one:
      <cfquery name="rsTags" datasource="cfsfwer">
          SELECT tags.tagName, tags.tagsID
          FROM tags, blogTagLink
          WHERE blogTagLink.blogID = <cfqueryparam value="#SESSION.blogID#" cfsqltype="cf_sql_numeric">
          AND tags.tagsID  = blogTagLink.tagID
      </cfquery>
      <cfset selectedTags = ValueList(rsTags.tagsID)>
      <cfquery name="rsAllTags" datasource="cfsfwer">
          SELECT *
          FROM tags
          ORDER BY tags.tagName
      </cfquery>
      So far this works just fine.  The output of #selectedTags# is correct.  Now I want to output #rsAllTags# and check to see if the record is ALSO in the #selectedTags# list, and if it is, change the class on the output, like this
      <ul>
      <cfoutput query="rsAllTags">
      <cfset temp = ListFind(selectedTags, #rsAllTags.tagsID#)>
           <cfif temp EQ 0>
                 <li class="tagnotselected""><a>#rsAllTags.tagName#</a></li>
           <cfelse>
                 <li class="tagselected""><a>#rsAllTags.tagName#</a></li>
           </cfif>
      </cfoutput>
      </ul>
      It doesn't work, and it is related to the variable #rsAllTags.tagsID#.  If I use a static value for this, it works fine.  Obviously, I need a dynamic value to deal with the output query.
      Any help would be appreciated.
        • 1. Re: Comparing a list with a query output
          Dan Bracuk Level 5
          If your db supports it, this type of query will give you exactly what you want and simplify your output.
          select tagid, tagname,
          case when x.tag_id is not null then 'tagselected' else 'tagnotselected' end included
          from tags left join (
          select tagid
          from tagblocklink
          where tagid = = <cfqueryparam value="#SESSION.blogID#" cfsqltype="cf_sql_numeric">
          ) x on tags.tagid = x.tagid
          order by tagname
          The output should require no if/else logic
          • 2. Re: Comparing a list with a query output
            Lee Crockett Level 1
            I'm using MYSQL, and I am not sure.  Thanks for putting this up, but, honestly that answer is a little over my head.  I'm struggling to follow it
            • 3. Re: Comparing a list with a query output
              Dan Bracuk Level 5
              run it and dump it.   make sure you delete the extra equal sign first
              • 4. Re: Comparing a list with a query output
                ilssac Level 5
                You need use the valuelist() function around your query.column to convert the record set into a list before you can search it.
                First try it witout the pound signs, those are unnecessary.
                <cfset temp = ListFind(selectedTags, rsAllTags.tagsID)>
                And then it is possible that you are not fully referencing the query record set and so you are only getting the first row for each iteration.  If so try this.
                <cfset temp = ListFind(selectedTags, rsAllTags.tagsID[rsAllTags.currentRow])>
                • 5. Re: Comparing a list with a query output
                  Thanks Dan:
                  I get errors when trying to run this.  The first is:
                  Unknown column 'x.tag_id' in 'field list'
                  I know that this is the right approach, just not sure how to get it
                  working.
                  This is what I'm running:
                  order by tagname
                  </cfquery
                  • 6. Re: Comparing a list with a query output
                    Thanks Ian:
                    I tried both of those and neither works.  The problem is definitely
                    related to the current row for me because when I output the variable
                    #temp#, I am getting a list of results.  This tells me that it is
                    running all the instances of rsAllTags.tagsID and not just the current
                    one.  I don't know how to get around it.  I thought that your last
                    suggestion:
                    would work, but it gives the same output.
                    • 7. Re: Comparing a list with a query output
                      ilssac Level 5
                      I would then output each part of the function and the function results for each itteration, or a sub-set of itterations if it is a large result set.
                      Check that each part and the results are as expected.
                      • 8. Re: Comparing a list with a query output
                        Dan:
                        Thank you so much for your expert help.  After working at this for a
                        while, I understood what was going on, made some corrections and got
                        it to work.  It is obvious to me that I need to spend more time
                        learning SQL!.  Thank you for taking the time to help.  Here is the
                        final code:
                        <cfquery name="rsNewTags" datasource="committedsardine">
                        case when x.tagid is not null then 'tagselected' else 'tagnotselected' end included
                        select tagID
                        from blogTagLink
                        where blogID = <cfqueryparam value="#SESSION.blogID#" cfsqltype="cf_sql_numeric">
                        ) x on tags.tagsID = x.tagid
                        order by tagname
                        </cfquery>
                        The cfdump for rsNewTags is this:
                                INCLUDED           TAGID           TAGNAME
                        1      tagnotselected           empty string assessment
                        2      tagselected           5                brain
                        3      tagnotselected           empty string collaboration
                        4      tagselected           10                digital
                        5      tagnotselected           empty string digital diet
                        6      tagnotselected           empty string evaluation
                        7      tagselected           4                exponential
                        8      tagselected           6                fluency
                        9      tagnotselected           empty string global
                        10      tagnotselected           empty string hardware
                        And the conditional statement is now this:
                        <cfoutput query="rsNewTags">
                        <cfif rsNewTags.included EQ "tagselected">
                        <li class="tagselected"><a>#rsNewTags.tagName#</a></li>
                        <cfelse>
                        <li class="tagnotselected"><a>#rsNewTags.tagName#</a></li>
                        </cfif>
                        </cfoutput>
                        • 9. Re: Comparing a list with a query output
                          Dan Bracuk Level 5
                          Regarding
                          <cfelse>
                          </cfif>
                          </cfoutput>
                          too much work.  all you need is
                          <li class="#something from your query#"><a>#rsNewTags.tagName#</a></li>
                          • 10. Re: Comparing a list with a query output
                            Wow, right you are.  I totally get it now.  Thanks so much, works like
                            a charm.
