2 Replies Latest reply on Apr 28, 2009 11:56 AM by sb4018
    Image_map Issues - Help!
    sb4018
      I have a delimna with my image maps. I'm using Robohelp Html v7 to create an online help
      system for an GUI application. In my topic I have an image. I'm using the image map tool to
      create popup boxes for each button on my image. In some of those popup boxes I reference
      another topic which also has an image that have popup boxes associated with its various
      buttons on the image. Now, when I test the topics individually by clicking on a button on the
      image a popup associated with that button displays just fine. However, when I test it
      altogether I'm running into some issues.
      Here are the steps:
      1.  I open the topic
      2.  I press a button on the image contained on that topic - a popup is displayed
           referencing another topic (2nd topic).
      3.  I press a button on the image in the 2nd topic, the popup associated with
           the 2nd topic does not display. Not only that, the 2nd topic popup goes
           away as well.
      4.  At this point, I'm back at my original topic. So, I press the same button. This
           time not only does the 2nd topic re-display in a popup but the popup associated
           with the button I pressed in step 3 from 2nd topic is now displayed.
      Is this a known bug in Robohelp? If so, is there a work-around? If not, can you
      suggest other options I can try?
        • 1. Re: Image_map Issues - Help!
          RoboColum(n) Level 5
          I believe the issue here is that popups, regardless of whether they are created from an image map or not, are not designed to work in this manner. A popup window has no visible method of closing it. It is closed simply by clicking anywhere on the window. Therefore by having a popup containing an image map on which you have to click to display a third topic is closing the original popup. The only way around this I can think of is to use hyperlinks inside the popup.
          Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
          • 2. Re: Image_map Issues - Help!
            sb4018 Level 1
            Thanks.  Your answer resolved my issue.  For those topics with popups, in the hyperlink I defined them to popup in the same frame.
