3 Replies Latest reply on Jun 7, 2009 9:30 PM by Bob Dix Photographer-E0Nmzu
    To Render or not to Render
    Joe Chott
      I am new to Premiere, so bear with me please.
      In looking through the forums and the documentation, it looks like some video imports as red, some as yellow, some as green (when placed on the timeline).
      Apparently there is hardware out there that works to help make everything green.  Rendering a preview will make everything green.
      But is there some way that I can take 5D Mk II video, and either convert it to something else or, failing that, permanently render?  I want to be able to save a project and come back to it and have everything playable without me having to re-render it every time.
      1. I have tried using just the plain output files from my camera.  I get jerky playback unless I render it first
      2. I have tried importing my camera files into Quicktime Pro, and then exporting at mp4.  I get jerky playback unless I render it first.
      3. I tried importing my camera files into CineForm Neo Scene , and exporting using their user guide.  The resulting files crash Premiere on import.  I can't do anything with them at all.
      So at this moment, my best workflow seems to be to import the camera files as is into Premiere, render them, and then begin work.  This takes EONS for any significant amount of video.  Is there any faster alternative?
      -Joe Chott
        • 1. Re: To Render or not to Render
          Curt Wrigley Level 4
          PLease read this thread that discusses the same issue in detail...
          How to transcode Canon 5D mark II H.264 video into something editable?
          Pr doesnt like the native format very much.
          • 2. Re: To Render or not to Render
            the_wine_snob Level 9
            Joe,
            One should have to do the Render only once, unless they make some change in the footage, i.e. a Title, an Effect, a Transition, and then should only have to re-Render just that section (see WAB - Work Area Bar). If you are doing a Render, and then upon restart of that Project, the Rendering is gone, there is another problem.
            The link provided does go into a lot of good discussion on these particular files. There is a second similar thread, IIRC, with more comments.
            • 3. Re: To Render or not to Render
              Level 1
              Adobe admit there is a performance problem with mov. files from Canon 5D Mark II  here in Australia and say a patch will becoming for CS4 ?
              We use Premiere Pro 1.5.1 the first version capable of handling High definition codecs and an  older Pentium  4 3.2 MHZ 800MHz FSB 2 Gb Ram and 500 Gb" C "and "D "Drives, it does a very good job and has done for 2.5 years in HD but, Canon's  5D mark II mov. has provided us with a problem on smooth timeline running to edit .
              You need to render all the clips first and if you have say 40 min timeline it will take about 5 hours  overnight and in the morning you have a very editable timeline.
              All the files run smoothly with the exception of a minor glitch with the camera speed of 30fps say to a Project setting which may need to be changed if say you use Pal at 25fps or 29.97 fps if you export to tape which is the cheapest way of getting the video to say a Sony Bravia 46" and if you make a mistake with High Definiton , you will certainly see it.
              Generally speaking the out put of the mov. files through Premier Pro 1.5.1 to tape is very professional, and the final result is stunning.
              Note: There certainly are issues with jerky running on the timeline without a very good Quad or Duo Core computer.Unless the isssue is poor perforformnace from CS4.
              Unfortunately Adobe's phone tech service in 4 years solved only one or two  ploblems , they are close to incompetent as you can get.
              Ps. The saving grace here is , is that premiere Pro is a marvellous product , but, the tech support is not a patch on Dell Computers who have often solved Adobe Portal support requests befor they have. it does not say much for the Technicians which is a great pity.
              When Premiere is working properly it is first class ##################
