2 Replies Latest reply on Apr 23, 2009 1:53 PM by [Jongware]
    Why cant i switch my file to a PDF file on INDESIGN?
      Im in a Computer Design class where we had to create a story board and the professor asked us to change our file into the smallest file size and make them into spreads. I have 109 pages and i did what i usually did by going into Adobe Presets and switching everything. But this time around, it notified me that the file has failed to export it into a PDF file. Can anyone give me some suggestions?
        • 1. Re: Why cant i switch my file to a PDF file on INDESIGN?
          SuperMacGuy Level 2
          This is the "Scripting" forum. Is this really a scripting/automation problem? It doesn't sound like it. Plus, there are a hundred reasons why a file might fail to export. You're going to have to be more detailed in what you did or did not do.
          • 2. Re: Why cant i switch my file to a PDF file on INDESIGN?
            Sure. First off, as you are clearly a beginner and this is your first post: learn the lingo. "What are elements, methods, and functions in InDesign called?" It seems a strange thing to ask from a (beginning) designer, but what if you want to draw a plane with semi-circular junctions? (That's a rectangle with rounded corners in ID.)
            Any particular reason you chose the scripting forum to post in? "Scripting" is writing lil' programs that can repeat tasks in ID.
            "Switch a file to PDF" -- nah. "Export to PDF". In fact, I'm surprised you din't call it that way because you used the Export function before...
            "i did what i usually did by going into Adobe Presets and switching everything" -- fah. A preset is just that -- a preset. ID has loads of them. You must mean the PDF presets; and there is a preset called 'Smallest file' (something like that).
            As for the actual problem, I have no idea. A quick google, though, using the exact phrase "indesign failed to export pdf" returns some 10,000 hits, and the first one http://hellbox.org/archives/000497.html is an interesting story just to read. Besides, it also mentions a few reasons why export may fail.
