4 Replies Latest reply on Apr 24, 2009 11:43 AM by Curt Wrigley
    Importing FCP Hi Rez from Final Cut with Encore Destination
      I wonder if i could get some advise and comment on trying to get the best Blu Ray encode from Final Cut.
      What I have done is this:
      I have imported a 60 minute Quicktime FCP file into Premier CS4. (The file was imported as HDV video from a Canon XHA1 and converted in FCP to 422Hi Rez). I set Premier to HDV and not Quicktime before the import. When the import finished, I notice that playback was very jerky, so I rendered the whole time line. This took about 5 hours. Following this, play back was perfect.
      So, what should my settings have been initially....might I have not set everything correctly. What settings should I have set initially?
      (I have not figured out how to export a sequence directly from FCP which 4.01 is supposed to do.)
      Now that it is play fine in Premier CS4  4.01, I am planning to use the dynamic link system to export into Encore CS4 .01 .  But before I do so, do I have to fill out copyright info in Premier...I noticed an area for this?
      I chose this work flow because I did not want to use the FCP's Compressor for make a Blu Ray. I want to use Encore's H264 compression which produces a smaller file and thus less disc space. I do understand that I could have left out Premier altogether and gone directly from Compressor to Encore, but then I would not have had the H264 choice..;is this right...I am not entirely au fait with all the terms:)
      So far, no crashes or weird behaviour. I am on a MacPro  Quad Core  2 Porcessor  2.8 GHZ processor.
      Tim
        • 1. Re: Importing FCP Hi Rez from Final Cut with Encore Destination
          Jim_Simon Level 8
          Edit with Premiere on a PC.
          (Sorry, I just had to go there.  I'll shut up now.)
          • 2. Re: Importing FCP Hi Rez from Final Cut with Encore Destination
            Curt Wrigley Level 4
            You captured hdv into FCP then FCP convertedthe hdv to ProRes intermediate format.  So, thats why exporting pro res to Pr and setting Pr to HDV did not work.
            I would suggest exporting xml the project from FCP and use the new IMPORT fcp feature in Pr CS4 .  Then you can DL link that to Encore to avoid the intermediate files.
            Or; Export an uncompressed final version from FCP and import that into Encore and let encore encode it for you.
            • 3. Re: Importing FCP Hi Rez from Final Cut with Encore Destination
              Level 1
              Thanks for the advice. I now have the project in Encore. While it played perfectly in Premiere, it cannot do so in Encore. Maybe this is because I have the settings set to the highest resolution- 1920 x 1080 and Blu Ray NTSC. I am trying to set up chapters and it is very jerky trying to get to the right place. Shou/ld I be doing this at a lower resolution and then changing things at the end?
              Also I currently have DVD Transcode set to automatic and Blu-ray Transcode set to Automatic.
              Are these settings going to look at the best on a 54" Samsung HDTV  1080i  ?  I notice a whole slew of choices in the drop down!!
              I am ploughing through the Lynda.com tutorials, but some of these questions don't seem to be answered there.
              I am planning on saving things to hard drive so I can test before burning...is this feasible on a mac?
              Tim
              • 4. Re: Importing FCP Hi Rez from Final Cut with Encore Destination
                Automatic normally works very well.  Of course the longer your program, the more agressive the encoding will have to be.
                How video plays within Encore should not be to big a concern.  When it encodes it, it should play fine from the disk.  This is assumumgin you are feeding it a quality video stream to start with.
