1. Re: Edits ruining posts times and order?
si conehead Apr 24, 2009 3:33 PM (in response to Claudio González) -
2. Re: Edits ruining posts times and order?
adobe-admin Apr 24, 2009 3:43 PM (in response to Claudio González)This is not very different from Web Crossing. If you updated an old message in Web Crossing it, too, got moved to the top of the list and appeared as if it was a new message. But in Web Crossing you could only edit within 20 minutes. Now you can edit until someone replies. So it wasn't as rampant and was only very noticeable if an administrator went in and edited a old message. John
3. Re: Edits ruining posts times and order?
Claudio González Apr 24, 2009 3:49 PM (in response to Claudio González)I have just remembered that Dorothy had already noticed this same behaviour:
http://forums.adobe.com/message/1888944#1888944
(and see also my post #190 in that same thread).
4. Re: Edits ruining posts times and order?
Claudio González Apr 24, 2009 4:12 PM (in response to adobe-admin)As you say, in the old forums this may have been hardly noticeable because of the short time for editing messages. Which brings in an interesting question: is the latitude here good/desirable?
I ask because I have seen several (or many? I don't know) people using the Reply button in the last posted message instead of that in the post they are answering. Which implies that there may be many later messages related with a given post, which remains nevertheless as "unanswered" and therefore editable. So the author of that message will be able to modify it many posts later in such a way that, willingly or unwillingly, at least some intermediate messages appear as hard to understad or simply foolish.
Maybe the 20 minutes limit wasn't so bad after all.
5. Re: Edits ruining posts times and order?
Phillip Jones Apr 24, 2009 6:13 PM (in response to Claudio González)I thought it was 30 minutes. It was relatively short, but wasn't bad though. At least SM/FF's Spell check would work in it if you remembered something to correct in time enough. One difference in this system regardless of whether the post has been posted two minutes or 2 hrs, the first time it directly replied to, you can not correct with the old system you had a Flat time limit even if someone replied as long as that 20-30 minute time had not elapsed, you could make corrections.
6. Re: Edits ruining posts times and order?
Kath-H Apr 24, 2009 11:34 PM (in response to Phillip Jones)It was 30 minutes. I just reply to the last post nearly all the time, because I've tried threaded view and didn't like it, so I'm just treating these forums like the old ones and tacking my replies on the end. If necessary I quote a snippet or put @xyz to clarify. One strange thing is that a host looked at a post of mine because it had been reported, but didn't edit it and sent me a message to say 'no problem'. The time on that post was changed to the time it was looked at.
7. Re: Edits ruining posts times and order?
John Joslin Apr 25, 2009 12:57 AM (in response to Kath-H)I am not in favour of restrictions generally, but leaving the edit window open indefinitely, and edits leaving no trace, can make a mockery of a thread.
I can't say it bothers me much but is is a(nother) flaw in the system.
8. Re: Edits ruining posts times and order?
Phillip Jones Apr 25, 2009 9:50 AM (in response to John Joslin)John Joslin wrote:
When you do edits there is a little window just below with either you name or User name you can add a comment to it and click a check mark and it will add that information to the editted version.
IF I edit imediately I don't use it. on the otherhand, If its been several hours or next day I do tick the check box.
I actually like it except you can edit to correct mispellings or the like after someone has commented to your post directly.
And this has been edited adding this line.
Message was edited by: Phillip Jones
9. Re: Edits ruining posts times and order?
dave milbut Apr 25, 2009 10:45 AM (in response to John Joslin)leaving the edit window open indefinitely, and edits leaving no trace, can make a mockery of a thread.
yes. it does.
10. Re: Edits ruining posts times and order?
dave milbut Apr 25, 2009 10:46 AM (in response to Phillip Jones)PjonesCET wrote:
do you have to state the obvious every single time?
11. Re: Edits ruining posts times and order?
Kath-H Apr 25, 2009 10:57 AM (in response to dave milbut)I actually like it except you can edit to correct mispellings or the like after someone has commented to your post directly.
Of course you have to know they are there. I expect you meant 'can't'.
12. Re: Edits ruining posts times and order?
Phillip Jones Apr 25, 2009 11:16 AM (in response to dave milbut)dave milbut wrote:
PjonesCET wrote:
When you do edits there is a little window just below with either you name or User name you can add a comment to it and click a check mark and it will add that information to the edited version.
I bet you a plug nickel many people that edit their post don't even realize, or pay attention to the box is there.
13. Re: Edits ruining posts times and order?
Yep your right. I meaant can't not can.
14. Re: Edits ruining posts times and order?
John Joslin Apr 25, 2009 11:21 AM (in response to Phillip Jones)PJ, did you know that it is not compulsory to reply to every post?
15. Re: Edits ruining posts times and order?
dave milbut Apr 25, 2009 11:33 AM (in response to Phillip Jones)PjonesCET wrote:
i'll bet you there are a lot of people who don't pay attention to what's going on around them, too.
16. Re: Edits ruining posts times and order?
Phillip Jones Apr 25, 2009 12:32 PM (in response to John Joslin)John Joslin wrote:
Yes
I don't reply to every post
17. Re: Edits ruining posts times and order?
Phillip Jones Apr 25, 2009 12:38 PM (in response to dave milbut)dave milbut wrote:
How true.
