1 Reply Latest reply on Apr 25, 2009 5:58 AM by heathrowe
    How to copy layers and maintain their content/name?
    superfetz Level 1
      For instance:
      I have a layer called "Dialog box" containing different symbols and I want to copy/paste it to another document or page and maintain the name and contents. But I always end up with the pasted content within a default layer "Layer 1" and when I want to duplicate it places the items inside my current layer and not in a new one.
      Any ideas people?
      TIA!
      /H
        • 1. Re: How to copy layers and maintain their content/name?
          heathrowe Most Valuable Participant
          Hierarchical Layer Copy command may assist.
          It's available at Fw Exchange.
          Here is a summary of it's purpose.
          Copy heirarchical layers without loosing the layer heirarchy.
          Usage:
          1. Select the layer you want to copy.
          2. Select Layer Copy from Commands -> Document menu.
          3. Switch to document were you want to copy the layer heirarchy
          4. Select Layer Paste from Commands -> Document menu.
          Known Limitations:
          - If resolution of both the documents are different then resampling is not done.
          - Do not close the source document or even change the page in source document.
          - Do not use this command across pages of same document.
          - Layer Hierarchy is pasted at center of the document.
          - Do not use this command for Web Layers.
