10 Replies Latest reply on Nov 24, 2011 2:41 AM by Ashish Vashisht
    how to request service with complexType
    master.card Level 1
      I implement service with Flex like:
      <mx:WebService
      wsdl="http://idme.identita.com:8080/andromeda/service/ws?wsdl" id="testService" showBusyCursor="true
      useProxy="
      false">
      <mx:operation name="process" result="resultHanlder(event);">
      <mx:request>
      <TokenDisplayAuthenticationRequest>
      <otp> {otp.text}
      </otp>
      <serialNumber> {serial.text}
      </serialNumber>
      </TokenDisplayAuthenticationRequest>
      </mx:request>
      </mx:operation>
      </mx:WebService>
      Our web service only one operation "process", but there are a lot of request & response. But it did not work, can some help me to check what problem in this code?
      Java code with CXF like:
      private static final QName SERVICE_NAME = new QName("http://www.identita.com/andromeda/services", "AndromedaService");
      private static final String WEB_URL="http://idme.identita.com:8080/andromeda/service/ws?wsdl" ;
      AndromedaService ss = new AndromedaService(wsdlURL, SERVICE_NAME);
      Andromeda port = ss.getAndromedaPort();
      TokenDisplayAuthenticationRequest authenticationRequest = new TokenDisplayAuthenticationRequest();
      authenticationRequest.setSerialNumber(serial);
        authenticationRequest.setOtp(otp);
         TokenDisplayAuthenticationResponse _process__return = (TokenDisplayAuthenticationResponse)port.process(authenticationRequest);
        • 1. Re: how to request service with complexType
          Michael Borbor Level 4
          What is the problem with your WS, does the call raise an error? Or your
          result comes empty?
          • 2. Re: how to request service with complexType
            master.card Level 1
            Very thank you for your reply, I just using Flex web service, and also not familiar with service, please take look at for me?
            The fault message like:
            [FaultEvent fault=[RPC Fault faultString="Required parameter 'androRequest' not found in input arguments." faultCode="EncodingError" faultDetail="null"] messageId=null type="fault" bubbles=false cancelable=true eventPhase=2]
            Web service URL:
            Full Flex client code:
            <mx:Application
            xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"
            <mx:Script>
            <![CDATA[
            import
            mx.rpc.events.FaultEvent;
            import
            mx.rpc.events.ResultEvent;
            import
            mx.controls.Alert;
            private function resultHanlder(e:ResultEvent):void
            Alert.show(
            'resultHanlder'
            msg.text=e.result.toString();
            private function falutHanlder(e:FaultEvent):void
            //Alert.show('falutHanlder');
            //msg.text=e.message.toString();
            msg.text=
            + e;
            </mx:Script>
            <mx:WebService wsdl="http://idme.identita.com:8080/andromeda/service/ws?wsdl" id="testService
            fault="falutHanlder(event)" showBusyCursor="
            true" useProxy="false">
            <mx:request>
            <otp> {otp.text}
            </otp>
            </serialNumber>
            </mx:request>
            </mx:operation>
            </mx:WebService>
            <mx:TextArea id="msg" height="400" width="500"/>
            <mx:TextInput id="otp"/>
            <mx:TextInput id="serial"/>
            <mx:Button label="sendMsg" click="testService.process.send();"/>
            </mx:Application>
            • 3. Re: how to request service with complexType
              The error states that you're not properly sending the parameters in your request; I cannot communicate with the remote server due to the security sandbox but I tried using the import web service and this is the code that I used to call to that service.
              <ws:AndromedaService id="myService">
                        <ws:process_request_var>
                             <ws:Process_request>
                                  <ws:andromedaRequest>
                                       <ws:TokenDisplayAuthenticationRequest>
                                            <ws:otp>{otp}</ws:otp>
                                            <ws:serialNumber>{serial}</ws:serialNumber>
                                       </ws:TokenDisplayAuthenticationRequest>
                                  </ws:andromedaRequest>
                             </ws:Process_request>
                        </ws:process_request_var>
                   </ws:AndromedaService>
              Hope this helps.
              • 4. Re: how to request service with complexType
                master.card Level 1
                Hi Machael, thank you for your help. code still some error:
                [FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://idme.identita.com:8080/andromeda/service/ws"] messageId=null type="fault" bubbles=true cancelable=true eventPhase=2]
                Implement like:
                id="myService" fault="falutHanlder(event)">
                <mx:TextArea id="msg" height="400" width="500" text="{myService.process_lastResult}" />
                <mx:Button label="sendMsg" click="myService.process_send();"/>
                • 5. Re: how to request service with complexType
                  Try debuggin' the ws using IE, flash player 10, and the SDK 3.2 there was a
                  limitation regading reading soap faults, but using the last combination you
                  could read more about your error, accoding to Adobe.
                  • 6. Re: how to request service with complexType
                    master.card Level 1
                    Hi Michael,
                    Here is SOAP request  I capture:
                    <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
                    <soap:Body>
                      <andromedaRequest xmlns="
                    http://www.identita.com/andromeda/services" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="IdentityDisplayAuthenticationRequest" versionMinor="0" versionMajor="0" id="req_id">
                       <identity>sramadan</identity>
                       <otp>123456</otp>
                      </andromedaRequest>
                    </soap:Body>
                    </soap:Envelope>
                    How to modify my request using Flex service?
                    Quinten
                    <mx:WebService wsdl="http://idme.identita.com:8080/andromeda/service/ws?wsdl" id="testService" fault="falutHanlder(event)" showBusyCursor="true" useProxy="false">
                         <mx:request>
                                   <otp> {otp.text} </otp>
                                   <serialNumber> {serial.text} </serialNumber>
                         </mx:request>
                         </mx:operation>
                    </mx:WebService>
                    • 7. Re: how to request service with complexType
                      lokhb
                      HI,
                      How to get the ws request in debug mode. I want to see the same complete request xml.
                      Pls help on this.
                      • 8. Re: how to request service with complexType
                        Ashish Vashisht
                        Hi
                        You can enable debug level logging on the Proxy service via the logging config. http://help.adobe.com/en_US/LiveCycleDataServicesES/3.1/Developing/WSc3ff6d0ea77859461172e 0811f00f7045b-7f42Update.html
                        The relevant category is Service.HTTP
                        Regards,
                        Ashish Vashisht
                        • 9. Re: how to request service with complexType
                          lokhb Level 1
                          Hi Ashish,
                          I need to see the web service - request xml from flex side, before going to server. I have enabled debug mode and almost checked the avail properties of the webservice instance, but not able to see the request xml.
                          Any idea ?
                          • 10. Re: how to request service with complexType
                            Ashish Vashisht Level 1
                            Hi
                            One option is, you can temporarily switch to a non-RTMP channel and use Charles or another proxy to have a look at the AMF request.
                            Regards,
                            Ashish Vashisht
