1 Reply Latest reply: Apr 27, 2009 5:07 PM by John.Kordas RSS
    Can you create a XML dialog dropmenu.
    John.Kordas Community Member
      I've currently got a script for In Design that presents the user a dialog and one of the dropmenus is populated by reading an xml file.
      here is the example
      var docNamesXMLFile = File("/c/pubcodes.xml");
      if(docNamesXMLFile != null){
      var myDocNames = docNamesXMLFile.open("r", undefined, undefined);
      if(myDocNames == true){
              var xmlDocNameStr = docNamesXMLFile.read();
          }else{
              alert("Could not load test.xml file.")
      docNamesXMLFile.close();
      var xmlDocN = new XML(xmlDocNameStr);
      Does Acrobat allow you to do something similar?
        • 1. Re: Can you create a XML dialog dropmenu.
          Here is an example of the xml file sitting on the C:\ drive called test.xml
          <xmlElement><item>product1</item><item>product2</item><item>product3</item><item>product4< /item>
          </xmlElement>
          The following is a simple dialog that has a dropmenu with the option of product1/product2/product3/product4. Is it possible to read the test.xml file and load the item options in the xml as the dropmenu dialog options?
          Dialog example:
          //Acrobat JavaScript Dialog
          //Created by DialogDesigner from WindJack Solutions
          var Sample1 =
                result:"cancel",
                DoDialog: function(){return app.execDialog(this);},
                strpop1:"",
                SetListSel:function(list,path){if(path.length == 0) return;
                eval("list[\""+ ((typeof path.join != "function")?path:path.join("\"][\"")) + "\"] = 1")},
                GetListSel:function(oLstRslts,path){
                   for(var item in oLstRslts){
                      if( ((typeof oLstRslts[item]=="number")&&(oLstRslts[item]>0))
                         || this.GetListSel(oLstRslts[item],path) )
                       {path.push(item);return true;}
                   return false;
                initialize: function(dialog)
                      var listpop1 =
                            "product1": -1,
                            "product2": -1,
                            "product3": -1,
                            "product4": -1,
                      this.SetListSel(listpop1, this.strpop1);
                      var dlgInit =
                            "pop1": listpop1,
                      dialog.load(dlgInit);
                commit: function(dialog)
                      var oRslt = dialog.store();
                      var path = new Array();
                      this.strpop1 = (this.GetListSel(oRslt["pop1"],path))?path.reverse():"";
                description:
                      elements:
                                  type: "view",
                                  elements:
                                              type: "view",
                                              align_children: "align_row",
                                              elements:
                                                          type: "static_text",
                                                          item_id: "stat",
                                                          font: "dialog",
                                                          type: "popup",
                                                          item_id: "pop1",
                                                          char_width: 8,
                                              type: "ok_cancel",
          // Example Code
          Sample1.strpop1 = "";
          if("ok" == Sample1.DoDialog())
                console.println("pop1:" + Sample1.strpop1);
