1 Reply Latest reply on Apr 27, 2009 7:12 AM by Gregory Lafrance
    Decimal Point data for Stacked Column Chart
    Sen Imagines
      I use a basic version of a Column chart for one of my projects. I use a stacked column chart with 2 data series namely "Expenses" & "Profit".
      I use decimal point numbers (with only two or three places after the decimal point) for both series.
      When I mouse over the bars of the output for tool tip, I view more numbers after the decimal point for some data.
      How to fix the decimal point to only 2 places & what is the reason for this behaviour?
      Attached is the sample output (output.gif) showing the above condition for the mentioned data.
      -Sen
        • 1. Re: Decimal Point data for Stacked Column Chart
          Gregory Lafrance Level 6
          Create an toolTipShow event handler and use a NumberFormatter to set the precision of the numbers (sample code from LiveDocs):
          <?xml version="1.0"?>
          <!-- formatters\MainNumberFormatter.mxml -->
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Script>
                  <![CDATA[
                      // Define variable to hold the number.
                      [Bindable]
                      private var bigNumber:Number = 6000000000.65;
              </mx:Script>
              <!-- Declare and define parameters for the NumberFormatter.-->
              <mx:NumberFormatter id="PrepForDisplay"
                  precision="0"
                  rounding="up"
                  decimalSeparatorTo="."
                  thousandsSeparatorTo=","
                  useThousandsSeparator="true"
                  useNegativeSign="true"/>
              <!-- Trigger the formatter while populating a string with data.-->
              <mx:TextInput text="{PrepForDisplay.format(bigNumber)}"/>
          </mx:Application>
