3 Replies Latest reply on Apr 27, 2009 1:47 PM by ntsiii
    Removing a collection of items from a ArrayCollection
    firdosh Level 1
      Hey,
                  I am trying to remove a collection of selected indices from a ArrayCollection object.
      orginalList = new ArrayCollection([1,2,3,4,5,6,7,8,9,5,3,5,7,4,3,4,6,7,5,3])
      var removeItemsCollection:Array =[ 0, 3 , 4, 5 , 11];
      var size:int = removeItemsCollection.length;
      for(var i:int=0; i < size; i++)
        orginalList.removeItemAt(_orginalList .getItemIndex(removeItemsCollection[i]));
      But I keep getting a
      RangeError: Index '-1' specified is out of bounds.
      at mx.collections::ListCollectionView/removeItemAt()[C:\autobuild\3.2.0\frameworks\projects\ framework\src\mx\collections\ListCollectionView.as:592]
      Firdosh
        • 1. Re: Removing a collection of items from a ArrayCollection
          Michael Borbor Level 4
          The problem is that I don't see an item 0 in your AC but there's one
          in your array so the first time it tries to delete the item it returns
          a -1 the search because there isn't an item 0 in your AC you'll
          probably add some logic to only try to delete an item from the AC if
          it's found
          Sincerely,
          Michael
          El 27/04/2009, a las 10:04, firdosh <forums@adobe.com> escribió:
          Hey,
                     orginalList = new
          ArrayCollection()
          orginalList.
          removeItemAt(_orginalList .getItemIndex(removeItemsCollection+));
          \3.2.0\frameworks \projects\framework\src\mx\collections
          Firdosh
          • 2. Re: Removing a collection of items from a ArrayCollection
            Gregory Lafrance Level 6
            This code illustrates checking to see if the item exists first:
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Script>
                <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable] private var orginalList:ArrayCollection =
                  private function init():void {
                    for(var i:int=0; i < size; i++){
                      if(orginalList.contains(removeItemsCollection[i])){
                        orginalList.removeItemAt(orginalList.getItemIndex(removeItemsCollection[i]));
              </mx:Script>
              <mx:TileList dataProvider="{orginalList}" columnWidth="15" columnCount="10"
                width="100%" height="100%"/>
              <mx:Button label="Remove Items" click="init()"/>
            </mx:Application>
            • 3. Re: Removing a collection of items from a ArrayCollection
              ntsiii Level 3
              One major issue with removing items from an array or collection is that when you remove an item, the indices are recalculated.  If you remove itemAt "zero" , at the next iteration of your loop, the previous item 1 is now at zero.
              one solution is to remove the items in reverse order, something like this (from memory)
                      for(var i:int=size-1; i >= 0; i--){
              Tracy Spratt
