2 Replies Latest reply on May 8, 2009 6:30 AM by Al Baker
    Where is the mysterious hiding client variable?
    Al Baker Level 1
      Periodically we are getting this crash with one of our domains:
      Element CHOOSEEVENT is undefined in CLIENT.
      Here is the code snippet where the error is generated.  The last line gives the error.
      Note that the code is buried in a cfif testing for the existence of client.chooseevent and that the immediate preceding SQL statement references the variable successfully!
      <cfif isdefined("client.chooseevent") and not request.listevent>
      <cfif IsDefined("Client.CustomerID")
      AND (Client.CustomerID is not 0)
      AND len(Client.CustomerID)>
      <cfset str1 = client.customerid>
      <cfset str1=replace(str1,"-","_","all")>
      <cfif not isdefined("request.qrySeletedEvent_#client.chooseevent#_#str1#")>
      <cfquery timeout="#application.querytimeout#"
      name="qrySeletedEvent" datasource="#request.dsn#"
      username="#request.dsnUsername#"
      password="#request.dsnPassword#">
      SELECT * FROM evdata
      WHERE evID=#client.chooseevent#
      AND evdel = 0
      AND evCST ='#client.customerid#'
      </cfquery>
      <cfset request["qrySeletedEvent_#client.chooseevent#_#str1#"] = qrySeletedEvent>
      We are using the original release of ColdFusion 8 Enterprise.  Client variables are stored in a database and the domain is NOT being load-balanced between two CF instances.
      Any ideas?
        • 1. Re: Where is the mysterious hiding client variable?
          BKBK Adobe Community Professional & MVP
          Place <cfparam name="client.chooseevent" default="test_value"> at the top. Then place <cfdump var="#client#"> at two appropriate places, to find out where and how the variable disappeared.
          P.S.: for the test server, not on the production server!
          • 2. Re: Where is the mysterious hiding client variable?
            Al Baker Level 1
            Since the failure is a rare event, what I did instead was do a <cfsavecontent> of a <cfdump var="#client#"> after the initial <cfif> and after every statement between it and the last statement where the variable shows up missing.
            Around that last two statements I placed a <cftry> with the <cfcatch> sending me an email of all the dumps.
            After a couple of days it happened and, sure enough, variable "chooseevent" was in "client" after every statement except the <cfquery>.  After it, the variable no longer existed in "client".
            Which, of course, makes no sense.
            So, after the initial <cfif> I decided to do a <cfset holdchooseevent=client.chooseevent> and use "holdchooseevent" throughout the remainder of the body of the <cfif>.  After several more days, there have been no apparent problems.
