2 Replies Latest reply on Apr 27, 2009 12:55 PM by Michael Borbor
    Asdoc tool
    anu3000
      Iam trying to generate dcoumentation for FLEX project. Found article explaining what needs to be done in order to generate classes from code.
      http://www.sebleedelisle.com/?p=401
      Iam stuck at Step-5 in the above article.
      -source-path src
      -doc-sources src
      don't know what to provide as src values? Can anybody help me.
        • 1. Re: Asdoc tool
          Barna Biro Level 3
          Hi there,
          Although I did not use such a tool, I think it is referring to the source path of your application and the source path to the application docs. Example: if you correctly set the ${project_loc} to point to your project folder then as the article says, you only need to point the tool to your source folder. If your source files are inside a folder called "whatever" inside your project folder then you'll need to set: -source-path=whatever // and if your doc files are in a folder called "myDocs" then you'd have something like this for the second argument: -doc-sources=myDocs
          Obviously, you have to play around with this a bit because as I said, I never set my stuff manually.
          Best regards,
          Barna Biro
          • 2. Re: Asdoc tool
            Michael Borbor Level 4
            I recommend you to read Using ASDoc in the flex documentation
            Sincerely,
            Michael
            El 27/04/2009, a las 14:18, anu3000 <forums@adobe.com> escribió:
            code.
            -source-path src
            -doc-sources src
