4 Replies Latest reply on Apr 27, 2009 4:56 PM by Rick Gerard
    Using shatter effect on moving video
    bertrenolds Level 1
      I've been trying for a few hours now to no avail! I have video of me skiing off a cliff with an explosion in the background, no problem. I have a buddie that you can see in the video and I am trying to make him shatter with the explosion, I found a good tutorial http://www.wonderhowto.com/how-to/video/how-to-create-an-outward-explosion-in-after-effect s-18774/view/ on making stuff explode, only difference is that he does it with a picture, no video. Does shatter not work when video is moving? Or do I have something not set right, with dudes instruction I made a pre-composed layer but no video would show up in the area I used the pen tool. Maybe I will just make my buddie on fire so I don't have to deal with this anymore.
        • 1. Re: Using shatter effect on moving video
          yenaphe Adobe Community Professional
          Andrew Kramer just released a tutorial that might help you greatly: Disintegration.
          • 2. Re: Using shatter effect on moving video
            bertrenolds Level 1
            I was looking at that tutorial, very in depth and long, my only problem is that I don't have green screen video but I'm sure I can use his techniques to make it work.
            So has anyone used the shatter effect that comes with AE on moving video and gotten good results?  Making my friend on fire looks good but I would still like to know about using the shatter effect on video, or does it only work with pictures and text?
            • 3. Re: Using shatter effect on moving video
              It definitly works on video, but i guess that the video of your friend you are using is all shatering, whereas you just want you friend to shatter right ?
              The doc page for the shatter effect also links to good tutorials and general help on how to use it.
              • 4. Re: Using shatter effect on moving video
                Shatter works just fine with any kind of footage but it shatters the entire layer. If you want to make something in a video shatter then you must separate it from the background and then you must replace area where your subject was in the original video. From the way you described your shot you'd have to roto or mask out your subject and then you'd have to borrow some of the background from before or after where you want your subject to blow up to fill in the hole.
                If the camera is locked off then you can just pick the spot where the explosion happens and do some Photoshop work to that frame. If the camera is panning with the subject then you'll have to pick the spot for the explosion to start, roto out your subject for at least a few frames, then fill in the hole left when you cut out your subject. There's no one click solution here. It's a lot of work, much of it by hand, and it could involve some tracking. Deciding after the fact that you want to insert an explosion is the hard way to do this. Planning and shooting specifically with the effect in mind is still hard, but it gives you the best chance for success.
