4 Replies Latest reply on Apr 28, 2009 12:44 AM by Barna Biro
    user feedback with maxChar attribute on TextInput
    rotts2
      I have a textinput with maxChars=6
      i would like to have some sort of user feedback when they attempt to type the 7th char.  (red border, tooltip, etc...)
      what would be the ideal way to achieve this?
      I don't see where there is an event dispatched when a user tries to type the 7th char ?
        • 1. Re: user feedback with maxChar attribute on TextInput
          ATIF FAROOQ Level 3
          hi,
             you can use change event of textfield and remove the maxChars=6 property
                                        change event handler should be like this
                                     function changeHandler(e:Event){
                                             if(e.target.text.length>6){
                                                      //////notifyUser
          and for redBorder you can use Form and apply stringValidator on your textField that length of characters in textField should be 6 or less if not then
          throw validation Errror . in that case flex shows red ToolTip on in front of the text field on which validation error occurred along with red border
             see this link for help on validators http://livedocs.adobe.com/flex/3/html/validators_3.html
          • 2. Re: user feedback with maxChar attribute on TextInput
            Barna Biro Level 3
            Hi there,
            The change event would be a solution but a slightly more efficient solution would be to simply listen for a keyDown event. Here's a fast example that hopefully will help you get on the right track:
            <mx:Application
                xmlns:mx            ="http://www.adobe.com/2006/mxml"
                backgroundColor     ="#FFFFFF"
                layout              ="absolute">
                <mx:Script>
                    <![CDATA[
                        import mx.controls.Alert;
                        import mx.events.FlexEvent;
                        import mx.controls.TextInput;
                        private static const ALLOWED_MAX_CHARS:int = 6;
                        private function onInputFieldFill(event:KeyboardEvent):void
                            if (event.charCode != Keyboard.LEFT &&
                                event.charCode != Keyboard.RIGHT &&
                                event.charCode != Keyboard.UP &&
                                event.charCode != Keyboard.DOWN)
                                var target:TextInput = event.currentTarget as TextInput;
                                if (target.text.length > ALLOWED_MAX_CHARS - 1)
                                    target.text = target.text.slice(0, ALLOWED_MAX_CHARS);
                                    Alert.show("You tried to add 7 characters!", "ERROR");
                </mx:Script>
                <mx:VBox
                    width               ="100%"
                    height              ="100%"
                    horizontalAlign     ="center"
                    verticalAlign       ="middle">
                    <mx:TextInput
                        id              ="userInputField"
                        keyDown         ="onInputFieldFill(event)"/>
                </mx:VBox>
            </mx:Application>
            The code I posted is not perfect, it's an older file of mine that I have found and edited a bit so don't use it as it is.
            Blog: http://blog.wisebisoft.com
            With best regards,
            Barna Biro
            • 3. Re: user feedback with maxChar attribute on TextInput
              rotts2 Level 1
              at first i used this approach, but it did not work the way i expected
              I am using an Item editor on a DataGrid cell for input.
              I think my issue was that My ItemEditor was extending Label instead of TextInput
              • 4. Re: user feedback with maxChar attribute on TextInput
                Barna Biro Level 3
                Hi again,
                Somehow, I totally forgot that we have a TextEvent class that might come in handy in such situations. Check this out: http://livedocs.adobe.com/flex/3/langref/flash/events/TextEvent.html Creating to TEXT_INPUT instead of a generic KEY_DOWN event might be the solution ( you can obviously play around with the stuff and maybe come up with a different solution too ).
                With best regards,
                Barna Biro
