7 Replies Latest reply on Apr 28, 2009 11:57 AM by Gregory Lafrance
    Why people do this?
    webvalue Level 1
      I am reviewing some sample code provided by Adobe Flex 2 and use them for my own learning purpose. Here is an area I don't fully understand and I hope someone can help me.
      In the photoviewer sample that you can launch from Help - Flex Start Page - More installed samples >> -, the class Gallery.as:
              public function fill(gallery:Object):void
                  this.name = gallery.id;
                  this.description = gallery.description;
                  this.selected = 0;
                  for (var i:int=0; i < gallery.photo.length; i++)
                      photo = new Photo(gallery.photo[i]);
                      photos.addItem(photo);
      Can you replace the sentence "photos.addItem(photo);" with "photos.addItem(gallery.photo[i]);"?
      In other words, why in the world should the code call new Photo(gallery.photo[i])?
      Thanks a bunch a lot.
        • 1. Re: Why people do this?
          ntsiii Level 3
          Please use a more desdcriptive subject for your posts.
          That line is calling the constructor of the Photo class to create a new instance of that class with the passed in image.
          The next line places a reference to that instance in an ArrayCollection.
          No, that is not the same.  Even if that resolves to a Photo instance, which i am not sure it does, the syntax you suggest would put a *reference* to that instance in the arrayCollection.  The given syntac cratesa new instance of the Photo class.
          Tracy Spratt
          • 2. Re: Why people do this?
            Gregory Lafrance Level 6
            Below is the full code for the class.
            This code is creating a new instance of the Photo class, which takes an object in its constructor.
            The code is taking the i indexed photo data from the gallery passed into the fill method.
            You could use photos.addItem(new Photo(gallery.photo[i]));
            package samples.photoviewer
                import mx.collections.ICollectionView;
                import mx.collections.ArrayCollection;
                import mx.collections.IViewCursor;
                [Bindable]
                public class Gallery
                    public var name:String;
                    public var description:String;
                    public var photos:ArrayCollection;
                    public var selected:int;
                    private var photo:Photo;
                    public function Gallery(gallery:Object=null)
                        photos = new ArrayCollection();
                        if (gallery != null)
                            fill(gallery);
                        this.selected = 0;
            • 3. Re: Why people do this?
              Ansury Level 3
              You should google some object oriented programming tutorials or articles. You may not be able to find much ActionScript specific OOP info but something like Java or C++ or another language should work fine to get a grasp of what's going on. Once you learn OOP in one language it's the same in all, but yeah this is a basic OOP concept you're asking about and it will help you immensely in the future if you understand it well.
              • 4. Re: Why people do this?
                webvalue Level 1
                First, thanks for all who replied.
                Second, yes I will make the subject line more specific and meaningful.
                Third, let me make my question more specific.  I understand new Photo() adds an instance of Photo class, but here I am wondering why it is needed.
                I think both "photos.addItem(photo)" and "photos.addItem(gallery.photo[i])" will end up with same data content for the ArrayCollection photos, except "photos.addItem(photo)" finished with a note that each record in photos is a Photo type. Thanks for bearing with me but is this correct? Is this called typecasting?
                Looks like in AS 3 people do a lot of these. What would be the benefit of doing this, in short and long term?
                Thanks again for everybody's help!
                • 5. Re: Why people do this?
                  gallery.photo[i]) is just data, not a Photo object. You can't add data using addChild(). photo in this case is a Photo object.
                  • 6. Re: Why people do this?
                    webvalue Level 1
                    Greg,
                    It is addItem(), not addChild().  BTW, I tested that both ways created the ArrayCollection photos virtually of the same because I used a Datagrid to display them. As I said, the only difference is that Photo type was noted if the instance was made.
                    • 7. Re: Why people do this?
                      Oh yeah, addItem(). Well in one case you are adding data object to the AC, in the other case adding a Photo object. Depends on your requiements and the value you see in storing data or a Photo object.
