10 Replies Latest reply on Sep 16, 2008 10:46 PM by Newsgroup_User
    What is a list of checked checkboxes called with same name to cfc?
    Level 7
      If i have say a list of user roles as checkboxes in a form and 2 or 3 of
      them are checked, what would I call that as a data type in cfargument
      in a cffunction inside a cfc?
      Also, Can I wrap 2 or 3 separate database interaction functions inside a
      cftransaction tag in the calling cfm page and have the cftransaction
      work as expected if one of the functions fails for some reason?
      Please excuse the newbie questions...
      Kind regards,
      Mark.
        • 1. Re: What is a list of checked checkboxes called with same name to cfc?
          Daverms Level 3
          Q1) The datatype should be the same that you have with your database.
          Q2) You want to have all your sql statements executed eventhough one (or) some of them fails?. Please clarify.
          • 2. Re: What is a list of checked checkboxes called with   same name   to cfc?
            Level 7
            Daverms wrote:
            > Hi,
            Hi Daverms
            What I mean is that I'm trying to follow the latest "trend" of putting
            all database queries into a cfc. So, say I wanted to add a user to a
            system where there was first a function to add the user, then a function
            to assign the roles into a many to many table via the checkboxes
            selected in the registration form. My question is, if I put those 2
            database functions inside a cftransaction block, will that cftransaction
            work as it would if I had done it the old fashioned way, like putting
            the queries themselves in the cfm page inside the cftransaction block?
            Am I being a little more clear now?
            As for question one.... what datatype would I choose for cfargument to
            accept the list of values chosen from the checkboxes selected? I can't
            seem to get it to work with any of the possible selections for data type
            in cfargument..
            Many thanks for your reply.
            Mark.
            • 3. Re: What is a list of checked checkboxes called with   same name   to cfc?
              Daverms Level 3
              Hi Mark,
              Thanks for the clarification :-)
              Q2) It seems you want to put separate cffunctions inside a cfc to do the CRUD. So here the <cftransaction> will work the same old fashioned way and there wont be any issues.
              Q1) Your <cfargument>'s type attribute should be matching your table's target field's datatype, that is lets assume you have a table named "users" and storing the roles in a field called "roles_assigned" which is of integer in nature, then you should declare your <cfargument> with the same datatype.
              • 4. Re: What is a list of checked checkboxes called with   same name     to cfc?
                Level 7
                the argument type will be string, since you will be passing a
                comma-delimited list.
                the transaction will work if you write it correctly. is it going to be a
                transaction over several queries in the same cfc function, or spanning
                different function calls?
                Azadi Saryev
                Sabai-dee.com
                http://www.sabai-dee.com/
                • 5. Re: What is a list of checked checkboxes called with   same name       to cfc?
                  Level 7
                  > Azadi Saryev
                  > Sabai-dee.com
                  Hi Azadi,
                  yes, I want to use the cftransaction wrapped around 2 or 3 different
                  functions that all reside in a single cfc.... like Daverms suggests, the
                  functions make up the CRUD, but I want to wrap them in a cftransaction
                  in some cases.
                  I hope this clears up my question, it looks like according to Daverms,
                  the cftransaction will work in this scenario just the same as if the
                  queries were directly written into the cfm page between the
                  cftransaction tag, which is the answer I was hoping for :).
                  thank you for your help,
                  Mark.
                  • 6. Re: What is a list of checked checkboxes called with     same name     to cfc?
                    Level 7
                    Daverms wrote:
                    > Hi Mark,
                    > be any issues.
                    Thanks a lot for that Daverms, I was hoping that 2 or 3 CRUD functions
                    from a single cfc wrapped in a cftransaction would work just the same as
                    the old fashioned way.
                    Regards,
                    Mark.
                    • 7. Re: What is a list of checked checkboxes called with   same name   to cfc?
                      Dan Bracuk Level 5
                      Adding complexity in the name of fashion? Bad idea.
                      • 8. Re: What is a list of checked checkboxes called with     same name     to cfc?
                        Level 7
                        Hi Dan,
                        I big part of me wants to agree with you in considering the learning
                        curve... it's kind of coldfusion, but not as I use to use it... Still,
                        I'll never be any kind of Guru, but at some levels the who
                        "encapsulation" thing makes sense on some levels even though there is a
                        pain of learning in this.. again.
                        See where you coming from anyway Dan.
                        Mark.
                        • 9. Re: What is a list of checked checkboxes called with same name to cfc?
                          Dan Bracuk Level 5
                          We had a thread in the last week or so where someone posted some of his test results that showed the use of cfc's increased runtime. For me that's another reason to only use them if there is a reason.
                          The best reason is to make the code available to non cold fusion apps.
                          The next best reason is to make the code reusable. However, cfc's are not the only way to do this.
                          There probably are some other reasons, but I've not come across them in my own work.
                          Any reasons that are purely philosophical are bad reasons.
                          • 10. Re: What is a list of checked checkboxes called with   same name   to cfc?
                            Level 7
                            > work.
                            Hi Dan,
                            Agreed actually, I may just go back to my good old fashioned way of
                            doing things... this is at this stage only for my own app anyway, so no
                            interest in code re-use on this one.
                            Mark.
