7 Replies Latest reply on May 4, 2009 4:40 PM by [Jongware]
    Random Fonts Scripting
    Julien-caetla
      Hi everyone.
      I'm workibng on a INDESIGN script which will help me to do what i want (how logical is this sentence...)
      I'm working on a french translated version of a american comics and i'd like to keep his manua handwriting for the release.
      To get a near perfect effect, i'd like to use different fonts, using some variants.
      I more or less understand the way the script work, but i don't have the javascript understanding to get it works.
      It would be something like that ( thanks to the Peter Spier solution) :
      - Assign randomly  a number from 1 to n (n being the maximum fonts used)  to each character.
      - Assign to each number a font.
      - Maybe (if I cand) creating a panel asking which font use for the script.
      I just don't know how i can do  RANDOM and ASSIGN.
      (in fact looks like I don't know a thing about javascript)
      If any of you got an idea.
      Ju
        • 1. Re: Random Fonts Scripting
          Julien-caetla Level 1
          Hi
          I found this APPLE SCRIPTwhich do what i need.
          on run
              local rnd, Nch
              tell application "TextEdit"
                  if front document exists then
                      if length of selection > 0 then
                          set Nch to number of characters of selection
                          repeat with i from 1 to Nch
                              set rnd to random number 3 from 0 to 3
                              if rnd = 0 then
                                  set font of character i of selection to "juan1"
                              else if rnd = 1 then
                                  set font of character i of selection to "juan2"
                              else if rnd = 2 then
                                  set font of character i of selection to "juan3"
                              else
                              end if
                          end repeat
                      else
                          set Nch to number of characters of front document
                              if rnd = 0 then
                                  set font of character i of front document to "juan1"
                                  set font of character i of front document to "juan2"
                              else
                              end if
                          end repeat
                      end if
                  else
                      error "Aucun document ouvert"
                  end if
              end tell
          end run
          How could i transform it in JAVASCRIPT ??
          Thank you
          Julien
          • 2. Re: Random Fonts Scripting
            Your example targets TextEdit, and InDesign is a bit more complicated. For example, in TextEdit you only have one 'text' -- InDesign has lots. The following script is a more-or-less literal translation, that assumes either you have some text selected, or the cursor is in the text thread that you want to work on.
            if (app.selection[0].length < 1)
            thetext = app.activeDocument.selection[0].parentStory;
            else
            thetext = app.selection[0];
            for (var i=0; i<thetext.length; i++)
            switch (Math.floor(Math.random()*3))
              case 0: thetext.characters[i].appliedFont = "Times\tBold"; break;
              case 1: thetext.characters[i].appliedFont = "Helvetica\tOblique"; break;
              case 2: thetext.characters[i].appliedFont = "Comic Sans MS\tRegular"; break;
            The math stuff around random() returns an integer value from 0 to 2 (inclusive). That value is used in the switch cases -- which is way more efficient than endless 'if..else' constructions.
            Notice the way the 'appliedFont' value is written: the '\t' is translated into a tab character on running, and that's how InDesign expects font names: "Font name [Tab] Style". Be sure to copy both font name and style name exactly, otherwise you will get errors.
            • 3. Re: Random Fonts Scripting
              Hello Jongware
              I will try that tomorrow.
              Thanks a lot for the time you passed on it.
              jU
              • 4. Re: Random Fonts Scripting
                Jongware
                Thanks a lot
                Your script work and it will be helpfull.
                Thanks a lot again.
                To finish the scippt, i will try to had a dialog box asking wich font i will use ( i like to fight myself )
                Thanks a lot again, you've just becomeone of my deities.
                Ju
                • 5. Re: Random Fonts Scripting
                  Smoothfluid Level 1
                  I was awake most of last night wondering how on earth I could create a word made of random typefaces. This could be one step in the right direction.
                  I have never scripted anything before. Where should I start?
                  Does this script only change the whole word?
                  Can you see a way that individual letters are assigned random fonts within the word?
                  • 6. Re: Random Fonts Scripting
                    An older thread is "Random Font Script?" (see the 'More like this' box on your right).
                    I knew I had written something like that a while ago, and Peter Spier found it back at: http://forums.adobe.com/message/1281781#1281781
                    As for starting scripting, download the Scripting tutorial at www.adobe.com/devnet/indesign/pdfs/indesigncs4_scriptingtutorial.pdf (for CS4; look around the site for CS3). Read that and try the examples. If you get stuck, you can (almost) always ask here.
                    • 7. Re: Random Fonts Scripting
                      Smoothfluid Level 1
                      Thanks Jongware,
                      I had read that other post but missed the "shouldn't be too hard to add random fonts to the mix" bit the first time around. I'll have another look and put some time aside for Scripting 101.
                      I hope it isn't too nuts, I'm a designer and even CSS makes my head spin. But keen to give it a go.
