8 Replies Latest reply on Feb 15, 2011 10:02 PM by sethusubra1
    Java AMFConnection client - what is service url?
    HamletDRC Level 1
      I can't get the AMConnection object to connect to me BlazeDS service. How can I determine the URL and endpoint of my service?
      My BlazeDS service is a simple, no parameter hello world:
      package example.blaze;
      public class HelloWorldService {
          public String getHelloWorld() {
              return "Hello From BlazeDS";
      The destination in the remoting-config.xml is configured like this:
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="remoting-service" class="flex.messaging.services.RemotingService">
          <adapters>
              <adapter-definition id="java-object"
                                  class="flex.messaging.services.remoting.adapters.JavaAdapter"
                                  default="true"/>
          </adapters>
          <default-channels>
              <channel ref="my-amf"/>
          </default-channels>
          <destination id="helloworld">
              <properties>
                  <source>example.blaze.HelloWorldService</source>
              </properties>
              <adapter ref="java-object"/>
          </destination>
      </service>
      I would expect this Java client to work, but it doesn't:
              AMFConnection amfConnection = new AMFConnection()
              amfConnection.connect("http://localhost:8080/blazeds/")
              Object result = amfConnection.call("helloworld.getHelloWorld")
      The error is:
      ClientStatusException
          message: java.io.FileNotFoundException: http://localhost:8080/blazeds/
          code: AMFConnection.Call.Failed
      I've tried a lot of different variations on this endpoint and can't get anything to work.
      What is the correct parameter to AMFConnection#connect(String) and AMFConnection#call(String, Object...)?
