3 Replies Latest reply on Apr 28, 2009 11:27 PM by ntsiii
    CheckBox and Alert
    GeorgeWS Level 1
      I must be the dumbest but...
      I have a checkbox.
      <mx:checkbox id="repLabel" Label="Rep" selected="{selectedItem.salesrep}" />
      I then want an Alert to pop up showing if its checked or not.
      Alert.show(repLabel.selected)
      All I get is an error while compiling that says Implicit coercion of a value of type Boolean to an unrelated type String
      I am stumped on how to just show true or false.
      George
        • 1. Re: CheckBox and Alert
          _Natasha_ Level 4
          Hi George,
          this showld works:
          Alert.show(repLabel.selected.toString())
          repLabel.selected is a Boolean, you showld convert it to string. trace works fine with all types.
          • 2. Re: CheckBox and Alert
            run,ryan! Level 3
            selected of check box indicates whether a toggle button is toggled    on (true) or off (false).
            when you assign it a value that's not boolean, it's casted to blooean automatically.
            so you should use other properties other than selected, maybe name
            <mx:checkbox id="repLabel" Label="Rep" name="{selectedItem.salesrep}" />
            Alert.show(repLabel.name)
            • 3. Re: CheckBox and Alert
              ntsiii Level 3
              And if you had done:
              Alert.show("repLabel.selected=" + repLabel.selected);
              That would have worked because the string concatenation causes an implicit toString().
              Tracy Spratt
