3 Replies Latest reply on Apr 28, 2009 8:57 PM by sreedharvaddi
    Error while calling HTTPService
    sreedharvaddi
      i am getting  [RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"] error while trying to call a htttpservice.
      the following is the code which i am using to call the httpservice. my flex app and the http service which i am trying to call is located on the same server. if i paste the URL in the browser and click enter i was able to retreive the data.
      but when i use the same URL in the flex its not working. i tried using an application called HTTPanalyzer which logs all the http requests
      made by all the applications.but i couldnt find the flex app making any call to the server at all. i.e. its not actually sending request at all.please help me
      <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml">
          <mx:Script>
              <![CDATA[
                  import mx.controls.*;
                  import mx.collections.*;
                  import mx.managers.PopUpManager;
                  import mx.core.Application;
                  import mx.events.*;
                  [Bindable]
                  private function passKeys():void{
                      var params:Object={};
                      params["bu"]=bu.text.toUpperCase();
                      params["poid"]=poID.text.toUpperCase();
                      params["poget"]=Application.application.poadd.poMetaData.toXMLString();
                      Alert.show(http_createPO.url);
                      Application.application.mode="A";
                      http_createPO.send(params);
          </mx:Script>
          <mx:HTTPService id="http_createPO" showBusyCursor="true" url="http://xxxx.com/WEBLIB_FX_DOC.SM_FX_PO.FieldFormula.IScript_createPO" result="Application.application.getPO(event)" resultFormat="xml" fault="Alert.show(event.fault.toString())"/>
          <mx:Button x="134" y="68" label="Create PO" id="createPO" click="passKeys()"/>
             <mx:TextInput x="166" y="11" id="bu"  keyUp="autocomplete(this.bu,event)" fontWeight="bold"/>
          <mx:TextInput x="166" y="37" id="poID" text="Next" fontWeight="bold"  maxChars="8"/>
      </mx:TitleWindow>
