4 Replies Latest reply on Apr 28, 2009 1:38 PM by Budd Tugly
    feeding data to colorPicker inside RichTextEditor
    Budd Tugly
      Hello all,
      new to the forum, kinda new to Flex. I have searched the forums, but cannot find anything related to my problem, so here goes:
      I have a RTE and I want to use the colorpicker subcontrol, but I need to load the color names and hex values from a data provider. I have this process working with a plain ol' colorPicker (just to test it), but I cannot get the colorPicker within the RTE to accept data.
      My data comes in a s XML from a PHP page, and is set to an ArrayCollection. With the standard colorPicker I can just set the dataProvider to the name of my ArrayCollection and it works dandy. But with the picker inside the RTE I get nothing. How can I accomplish getting this data to the RTE colorPicker? Thanks.
        • 1. Re: feeding data to colorPicker inside RichTextEditor
          Gregory Lafrance Level 6
          myRTE.colorPicker.dataProvider = myArrayColl;
          • 2. Re: feeding data to colorPicker inside RichTextEditor
            Budd Tugly Level 1
            Thanks.
            Yep, that's what I thought as well. but no luck. I get standard hex values populated into the colorPicker. this colorpicker  is inside a TabNavigator. Do I need to target it as such? I ask because I have a function to remove unneeded buttons from my RTE which states:
            myRTE.toolbar.removeChildAt(0);
            and it works fine. I do not need to specify it as myTabNavigator.myCanvas.myRTE.toolbar.removeChildAt(0);
            • 3. Re: feeding data to colorPicker inside RichTextEditor
              Can you post your code to create and set the colorpicker, and the colection?
              • 4. Re: feeding data to colorPicker inside RichTextEditor
                Budd Tugly Level 1
                Okay, my data is formated thusly:
                <root>
                     <item>
                          <label>185 Red</label>
                          <color>0xee3a43</color>
                     </item>
                     <item>
                          <label>186 Red</label>
                          <color>0xe51937</color>
                     </item>
                     <item>
                          <label>199 Red</label>
                          <color>0xed174f</color>
                     </item>
                </root>
                Here is my code to retrieve the data via HTTPService:
                [Bindable]
                private var myInk:ArrayCollection;
                private function getInkData() :void
                var inkparams:Object;
                myInkService.send(inkparams);
                private function inkresultHandler(event:ResultEvent):void
                myInk = event.result.root.item as ArrayCollection;
                Which set the data to an ArrayCollection named myInk. And this works fine with my colorpicker:
                <mx:ColorPicker x="298" y="445" dataProvider="{myInk}"/>
                BUt when I try to format the RTE ("textInputBox") with the following function (called upon RTE creationComplete)
                public function formatRtfBox():void
                    textInputBox.toolbar.removeChildAt(2);
                    textInputBox.toolbar.removeChildAt(3);
                    textInputBox.toolbar.removeChildAt(4);
                    textInputBox.toolbar.removeChildAt(5);
                    textInputBox.toolbar.removeChildAt(10);
                    textInputBox.toolbar.removeChildAt(11);
                    textInputBox.colorPicker.dataProvider = myInk;
                no dice.
                I hope I didn't leave anything out.
