0 Replies Latest reply on Apr 28, 2009 2:10 PM by Steven..
    Script for font managment
    Steven.. Level 3
      I often get a file created with the Indesign Package function. The fonts are in the Fonts folder and I have to create a shortcut in the Indesign Fonts Folder, for the Fonts not to be missing. So I created a Script that adds this shortcut
      var fontFolder = Folder(File(BridgeTalk.getAppPath("indesign-"+app.version)).parent+'/Fonts/');
      if(app.documents.length){
           var doc = app.activeDocument;
           var docFontsFolder = File(doc.filePath+'/Fonts/');
           if(docFontsFolder.exists==true){
                var rapidDlg = new Window('dialog',"Select name for shortcut",undefined);
                buildWindow();
                var result = '';
                rapidDlg.show();
                if(result.length){
                     var newShortcut= File(fontFolder+'/'+result);
                     if (newShortcut.exists==false){
                          if(newShortcut.createAlias(docFontsFolder.fsName)) {
                               app.updateFonts();
                               alert('Shortcut has been created');
                     else{
                          alert('Creating shortcut has failed');
                     else{
                          alert('Shortcut by this name already exists, please try again with new name');
                else alert('No Font Folder can be found');
      else{
      alert('No Documents are open')
      function buildWindow(){
      // Properties for rapidDlg.EditText1
           rapidDlg.EditText1 = rapidDlg.add('edittext',undefined,undefined);
           rapidDlg.EditText1.characters = 50;
      // Properties for rapidDlg.Group1
           rapidDlg.Group1 = rapidDlg.add('group',undefined);
           rapidDlg.Group1.alignment = ['right',' '];
      // Properties for rapidDlg.Group1.Button1
           rapidDlg.Group1.Button1 = rapidDlg.Group1.add('button',undefined,"OK", {name:"ok"});
           rapidDlg.Group1.Button1.onClick = function(){
                result=rapidDlg.EditText1.text;
                rapidDlg.close()
      // Properties for rapidDlg.Group1.Button2
           rapidDlg.Group1.Button2 = rapidDlg.Group1.add('button',undefined,"Cancel", {name:"cancel"});
      and another script to remove your shortcuts
      var  fontFolder= Folder(File(BridgeTalk.getAppPath("indesign-"+app.version)).parent+'/Fonts/');
      var allFiles=fontFolder.getFiles('*');
      var arrayOfAlias=new Array();
      for(var i=0;i<allFiles.length;i++){
           if(allFiles[i].alias){
                arrayOfAlias[arrayOfAlias.length]=(allFiles[i].displayName);
      if (arrayOfAlias.length){
           var rapidDlg = new Window('dialog',"Remove Shortcuts",undefined);
           buildWindow();
           rapidDlg.show();
      else{
                alert('No Shortcuts Found');
           rapidDlg.orientation = "row";
           rapidDlg.Group1.orientation = "column";
      // Properties for rapidDlg.Group1.ListBox1
           rapidDlg.Group1.ListBox1 = rapidDlg.Group1.add('listbox',undefined,undefined, {items:arrayOfAlias});
           rapidDlg.Group1.ListBox1.selection = 0;
           rapidDlg.Group1.Button2 = rapidDlg.Group1.add('button',undefined,"Remove");
           rapidDlg.Group1.Button2.onClick = function(){
                File(fontFolder+'/'+rapidDlg.Group1.ListBox1.selection.text).remove();
                rapidDlg.Group1.ListBox1.remove(rapidDlg.Group1.ListBox1.selection);
      // Properties for rapidDlg.Group2
           rapidDlg.Group2 = rapidDlg.add('group',undefined);
           rapidDlg.Group2.alignment = [' ','top'];
           rapidDlg.Group2.orientation = "column";
      // Properties for rapidDlg.Group2.Button1
           rapidDlg.Group2.Button1 = rapidDlg.Group2.add('button',undefined,"OK", {name:"ok"});
      Steven
      http://scriptui.com
