• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
password protect cfm files
Guest
Sep 14, 2008 Sep 14, 2008
Hi i have a website being hosted on a server which other clients have access to, is there a way of protecting my files, so they can not be edited, if so what would be the best way to do this?
TOPICS
Advanced techniques
Views
1.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
One easiest method is to pre-compile your cfm files using the cfcompile.bat file in the CFSERVERROOT/bin/ folder.
- Prasanth
Votes
Translate
Translate
Report
Report
Guest
ok many thanks i have found the compiler, but not sure where to set the file locations?
i have tried cfcompile C:/ColdFusion8/wwwroot/website2 C:/ColdFusion8/wwwroot/website2 C:/
but no file is created?
Votes
Translate
Translate
Report
Report
Guest
ok i have now created the files with the incripted code, i then ftp the files to the websever, and now i get this error
500 coldfusion.runtime.CfJspPage._setCurrentLineNo(I)V
Votes
Translate
Translate
Report
Report
LEGEND ,
Was the machine you compiled (not encrypted, btw) the files on the exact
same CF revision and operating system as the one you're trying to run them
on?
Adam
Votes
Translate
Translate
Report
Report
LEGEND ,
> on?
Oh, and - naturally - the same JVM version. That's probably the most
important one of the three!
Adam
Votes
Translate
Translate
Report
Report
Guest
Sep 15, 2008 Sep 15, 2008
Hi Many thanks
i compiled them on my local machine, as the webserver i am hosting on is shared so i dont have access..
i am running vista with the latest JVM, i am sure the webserver is windows 2000.. what would be the best thing to do?
Votes
Translate
Translate
Report
Report
LEGEND ,
Well in my (limited) experience, one will run into problems if one's
compiling files on on OS and running them on another. I have had problems
compiling on XP and trying to deploy on 2k3. I'm not entirely sure whether
it was a JVM version difference or an OS version different; but would not
expect files compiled on on JVM version to work on another.
You can check your JVM version with this code:
{code}
<cfset oJvm = createObject("java", "java.lang.System")>
<cfdump var="#oJvm.getProperties()#">
{code}
Look @ the java.version value (I guess... there's a few in there that
reflect kinda the same info).
I suppose you could write some code to compile your files progammatically,
using <cfexecute> to call cfcompile.bat. Or check what cfcompile.bat
actually does, and call whatever it is directly. Then you could run that
code on the remote box.
First thing to do though before getting too carried away with that sort of
thing is to get onto the same Java version as the server, and compile the
files as that version, and try again. It might be best to just compile one
test file whilst you're experimenting, to save some time.
Adam
Votes
Translate
Translate
Report
Report
Guest
ok thanks the webserver is running version 1.4.2_09
so if i have a higher version how do i roll back to this version?
or would it be easier to use <cfexecute> ? if so how would you write this?
Votes
Translate
Translate
Report
Report
LEGEND ,
heh. it looks to me that even CF version is different on your host!
1.4.xx JVM was used in CF MX 7... CF8 uses 1.6.xx by default...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Votes
Translate
Translate
Report
Report
LEGEND ,
Sep 16, 2008 Sep 16, 2008
LATEST
I suggest *you* try and write your own code, and if you have any problems,
show us what you've done, and where it's not working, and then we'll try to
help.
Adam
Votes
Translate
Translate
Report
Report
LEGEND ,
> locations?
Which part are you not sure about?
You need to set the three paths towards the top of the file:
set CFUSION_HOME=C:\ColdFusion8
set J2EEJAR=C:\ColdFusion8\runtime\lib\jrun.jar
set WEBINF=C:\ColdFusion8\wwwroot\WEB-INF
Are those correct, given the descriptions given in the file?
Have you read the docs?
http://livedocs.adobe.com/coldfusion/8/htmldocs/deploying_5.html
Adam
Votes
Translate
Translate
Report
Report
Advocate ,
(I am not sure this will work out or not, Give a try anyway!)...
Just go and delete all the files (i.e, compiled templates) under your "cfclasses" directory, and then do the cfcompile again.
Votes
Translate
Translate
Report
Report
Resources
Documentation
