I am needing to make the flv loop from my .fla file which contains .flv files. I know there is a piece of AS 3.0 I need in order to make them loop/make the entire movie loop but I am not sure what it is.
are you using the flvplayback component or netstream class or video class to display your flv?
Well, I just imported the movie and it created the FLV for me; in other words, I didn't code it...
you imported an flv into the flash ide and assigned it to a timeline?
yes
Well,
in AS2 you need to use this code in the flv object:
on (complete){
this.autoRewind=true;
this.play();
Hope it helps
He's using AS3.
If it's on the timeline as you said then it seems on the last frame or the frame after that you could have code telling it to gotoAndPlay(1) though I'm not sure how you do that in as3.
