3 Replies Latest reply on Apr 30, 2009 1:58 AM by Kenneth Brøgger
    Moving layer + all keyframes
    Kenneth Brøgger
      Hi
      I need to move a layer, and all of its containing keyframes.
      Info: I have several layers, listed above eachother as a list compared to a vertical menu. I would like to dublicate these layers, with its animation, instead of animating all of it...
      Can this be done, in a easy and timesaving way?
      Thank you very much.
        • 1. Re: Moving layer + all keyframes
          TimeRemapper Level 4
          Hey Kenneth.
          Are you trying to do one thing, or two separate things?
          If you're tyring to move a layer's positon overall, but it's position has already been animated, you can:
          • Move the CTI over a keyframe
          • Select the word "Position" in the timeline (it will highlight all position keyframes)
          • Adjust the position of the layer, offestting it as needed, and all other keyframes will be offset as well
          or,
          • Create a Null
          • Parent your layer to the Null
          • Move the Null to offset the position of the animated layer
          You also seem to be wanting to duplicate a series of layers.
          I would suggest selecting all of the layers in question, "precomposing" them, and duplicating the precomp (then doing whatever you needed to the duplicate).
          • 2. Re: Moving layer + all keyframes
            elaine montoya Level 3
            I'm not sure if I completely understand your question...so let me clarify first.
            - you have multiple layers you want to duplicate because you need to re-use them and you don't want to have to redo them again
            If this is correct, simply:
            - precompose the layers
               - in the timeline, select all the layers
               - Layer > Pre-compose
            - then, duplicate the new composition as need be
               - select the new composition
               - command | control d
            Is this what you are trying to do?
            good luck!
            elaine
            • 3. Re: Moving layer + all keyframes
              Kenneth Brøgger Level 1
              Hi Elaine and Steve
              Thank you very much... Steves answer did the job... Thank you again guys!
