5 Replies Latest reply on Sep 21, 2008 12:22 AM by maluamike
    deleting rollovers
    wombat2536
      Hi All
      I'm using Dreamweaver 8 in XP.
      I have just deleted some rollovers from a table in a site I am developing. I have done this by deleting the image in the table, however when I go into the code there is still reference to the rollover gif images I used. Why are these still there and how do I remove them?
      Any help would be appreciated.
        • 1. Re: deleting rollovers
          Level 7
          Let's see the page.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "wombat2536" <webforumsuser@macromedia.com> wrote in message
          news:gauhco$704$1@forums.macromedia.com...
          > Hi All
          > I
          > the
          > these
          • 2. Re: deleting rollovers
            Level 7
            wombat2536 posted in macromedia.dreamweaver:
            > remove them?
            I think it will do what you want if you select the image, then delete
            the link in the properties panel first.
            Mark A. Boyd
            Keep-On-Learnin' :)
            • 3. deleting rollovers
              CaryD Level 2
              Just as plus(+) in the behavior panel adds behavior code, minus(-) should remove it, unless it's not possible for some reason.
              • 4. Re: deleting rollovers
                Level 7
                as a guess- i'd venture the preload stuff in the body tag was still there
                after the rollover images were deleted
                click on the <body> tag in the list of tags in the lower left margin of
                design view.
                Then open the "Behaviors" panel and delete the Preload behavior.
                > Behavior code is added with the plus(+) and should be removed with the
                > minus(-), unless it's not possible for some reason.
                Alan
                Adobe Community Expert, dreamweaver
                http://www.adobe.com/communities/experts/
                • 5. Re: deleting rollovers
                  maluamike
                  Hi all thanks for the help, yes you were right it was the preload stuff that was still there. I have removed that and all is well, thanks again.
                  PS. I've had to relogin under a different name as for some reason I could not get in using wombat2536.
