3 Replies Latest reply on Apr 29, 2009 11:48 AM by bobskid
    Flex State manipulation
    bobskid
      is there a way to change states from within a particular state?
      if i define my different states in a main.mxml file how do i change states from a state that i switch to.
      for example i have a login button that changes state to a login screen --- when you click the submit button i want to switch to
      a different state only that state is defined back in my main.mxml file??  is there an easy way to do this?
        • 1. Re: Flex State manipulation
          ATIF FAROOQ Level 3
          hi,
             currentState='your sate name' this is the general method to switch from one state to antoher
          • 2. Re: Flex State manipulation
            Gregory Lafrance Level 6
            This code should help:
            ----------- MyVBox.mxml ---------------
            <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%" horizontalAlign="center">
              <mx:Label text="Component State"/>
              <mx:Button label="Main State" click="mx.core.Application.application.currentState=''"/>
            </mx:VBox>
            --------- MainApp.mxml --------------
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              xmlns:comp="*" horizontalAlign="center" width="100%" height="100%">
              <mx:Script>
                <![CDATA[
              </mx:Script>
              <mx:Label id="lbl" text="Main State"/>
              <mx:states>
                <mx:State name="componentState">
                  <mx:RemoveChild target="{lbl}"/>
                  <mx:RemoveChild target="{chgBtn}"/>
                  <mx:AddChild>
                    <comp:MyVBox/>
                  </mx:AddChild>
                </mx:State>
              </mx:states>
              <mx:Button id="chgBtn" label="Component State" click="currentState='componentState'"/>
            </mx:Application>
            • 3. Re: Flex State manipulation
              bobskid Level 1
              Thank you so much for your quick responses -- the mx.core.Application.application.currentState did the trick!!
              Much appreciated!
              Bob
