2 Replies Latest reply on Apr 30, 2009 6:07 AM by Gregory Lafrance
    Multiple chart effects conflicting with each other
    Thorn, Inc. Level 1
      Hello all!
      Issue Description:
      -  Two chart series of two different series types (mx:ColumnSeries and mx:LineSeries)
      -  Trying to run two different chart data effects (mx:SeriesZoom and mx:SeriesSlide) simultaneously
      -  Having some sort of conflict
      My application is more complex than this, but this is a good example of the type of thing that's happening on our chart when the data provider changes:
      1)  Please compile and run the following code.
      2)  Then click the button at the bottom of the application.
      3)  Notice how after the line series gets removed, it appears for a second, then disappears without using its hide and show effects.  Then it reappears, but this time using the appropriate chart data effect.
      Can anyone tell me how to fix this?
      Anton
      -----------------------------   THE CODE:  -------------------------------
      <?xml version="1.0"?>
      <!-- charts/MultipleSeries.mxml -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" width="100%"
      height="100%">
        <mx:Script>
          <![CDATA[
               import mx.collections.ArrayCollection;
              [Bindable]
              public var SMITH:Array = [
                 {date:"22-Aug-05", close:42.87},
                 {date:"23-Aug-05", close:45.74},
                 {date:"24-Aug-05", close:48.77},
                 {date:"25-Aug-05", close:44.06},
              [Bindable]
              public var DECKER:Array = [
                 {date:"22-Aug-05", close:49.59},
                 {date:"23-Aug-05", close:45.3},
                 {date:"24-Aug-05", close:43.71},
                 {date:"25-Aug-05", close:47.88},
              public var year:int = 1;
              public function changeProvider():void {
                  if (year == 2) {
                      lineSeries.dataProvider=DECKER;
                      colSeries.dataProvider=SMITH;
                      b1.label="View Second Year Data";
                      year=1;
                  } else {
                      lineSeries.dataProvider=SMITH;
                      colSeries.dataProvider=DECKER;
                      b1.label="View First Year Data";
                      year=2;
        </mx:Script>
        <!-- Define chart effects -->
          <mx:SeriesSlide
              id="slideIn"
              duration="1000"
              direction="right"
          <mx:SeriesSlide
              id="slideOut"
              duration="1000"
              direction="left"
        <mx:SeriesZoom id="zoomOut"
           duration="2000"
           minimumElementDuration="50"
           elementOffset="50"
           verticalFocus="top"
           horizontalFocus="left"
           relativeTo="series"
        <mx:SeriesZoom id="zoomIn"
           duration="2000"
           elementOffset="-50"
           verticalFocus="top"
           horizontalFocus="right"
           relativeTo="series"
        <mx:Panel title="Multiple Data Series" width="100%" height="100%">
           <mx:ColumnChart id="myChart"
              dataProvider="{SMITH}"
              showDataTips="true"
              height="100%"
              width="100%"
              <mx:horizontalAxis>
                 <mx:CategoryAxis categoryField="date"/>
              </mx:horizontalAxis>
              <mx:verticalAxis>
                 <mx:LinearAxis minimum="40" maximum="50"/>
              </mx:verticalAxis>
              <mx:series>
                 <mx:ColumnSeries
                           id="colSeries"
                      xField="date"
                      yField="close"
                      displayName="SMITH"
                      showDataEffect="zoomIn"
                      hideDataEffect="zoomOut"
                 </mx:ColumnSeries>
                 <mx:LineSeries
                           id="lineSeries"
                      dataProvider="{DECKER}"
                      xField="date"
                      yField="close"
                      displayName="DECKER"
                           showDataEffect="slideIn"
                           hideDataEffect="slideOut"
                 </mx:LineSeries>
              </mx:series>
           </mx:ColumnChart>
           <mx:Legend dataProvider="{myChart}"/>
        </mx:Panel>
        <mx:Button id="b1" click="changeProvider()" label="View Second Year Data"/>
      </mx:Application>
