5 Replies Latest reply on Sep 14, 2008 2:10 PM by quilterin
    navigation in template based sites: how to show the active page
    quilterin
      I gave each link and each page an id. Using the context selector #link1 #page1 a {color x} works perfektly if the pages are single. If they are fixed to a template where I put this rule to the css-sheet, it doesn't work. Must the rule be written in each pages head? If yes, how can I make this part editable and what text must be written into it?
        • 1. Re: navigation in template based sites: how to show the active page
          Level 7
          Actually, those are now called 'descendent selectors', and in your case, the
          proper order would be
          #page1 #link1
          (it should be read from right to left - this one selects a#link1 that is
          contained on body#page1)
          There would be several ways to do this -
          1. Rather than keying your links to an ID in the body tag, just place a
          small embedded stylesheet in the head of each child page that explicitly
          sets the styles for the desired a#link. This stylesheet would go in the
          editable region in the head of the page called "head".
          2. If you REALLY want to use the ID in the body tag, then make the ID
          attribute an editable attribute, which will allow you to change it on each
          page using MODIFY | Template Properties.
          I much prefer method 1 due to its simplicity....
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "quilterin" <webforumsuser@macromedia.com> wrote in message
          news:gagbtc$g1k$1@forums.macromedia.com...
          >#page1
          > a
          > rule
          > and
          • 2. Re: navigation in template based sites: how to show the active page
            Level 7
            Another, even simpler, method is to use a javascript to automatically
            highlight the current page menu item (and parent menu items as well if
            desired). That way you need add absolutely nothing to your Child page's
            html body. Simply add it once to your template and you are done.
            I offer two DW Extensions that do this for you.
            A free one and a more capable commercial one:
            http://divahtml.com/products/divaGPS/current_menu_location.php
            The free version might well be all you need.
            E. Michael Brandt
            www.divahtml.com
            www.divahtml.com/products/scripts_dreamweaver_extensions.php
            Standards-compliant scripts and Dreamweaver Extensions
            www.valleywebdesigns.com/vwd_Vdw.asp
            JustSo PictureWindow
            JustSo PhotoAlbum, et alia
            • 3. Re: navigation in template based sites: how to show the active page
              quilterin Level 1
              "....1. Rather than keying your links to an ID in the body tag, just place a
              editable region in the head of the page called "head"...."
              How must this stylesheet look like?
              And if I want to change anything, I must change it manually in each single Page?
              "...make the ID attribute an editable attribute, which will allow you to change it on each
              page using MODIFY | Template Properties".
              That is what I did and as I said, it works with the single pages, after I took them off the template.
              Did I get it right that it won't work at all in the template css-stylesheet or is there simply a special line where these new descendet selectors must be placed?
              >#page1
              > a
              > rule
              > and
              • 4. Re: navigation in template based sites: how to show the active page
                Level 7
                > Page?
                Yes, but you'd have to do it that way anyhow. Unless you use something like
                what E. Michael Brandt is suggesting.
                > took
                You are confused. Editable attributes only work with template controlled
                pages. If you remove the page from template control, then you will no
                longer have this function.
                <!-- InstanceBeginEditable name="head">
                <style type="text/css">
                a#link1 { color:blue; background-color:orange; }
                </style>
                <!-- InstanceEndEditable -->
                </head>
                news:gaglt8$q9j$1@forums.macromedia.com...
                > place a
                > Page?
                > change it on each
                > took
                > css-stylesheet or
                > placed?
                > >#page1
                > > to
                > > a
                > > the
                > > rule
                > > and
                • 5. Re: navigation in template based sites: how to show the active page
                  quilterin Level 1
                  Thanks, everything works now perfectly!
