8 Replies Latest reply on Apr 10, 2014 8:17 PM by kcroy2011
    JPEG Library Editor
    LostMIke Level 1
      Why am I getting a "Premature End of JPEG File" error in a JPEG Library Editor pop-up?
      It happens every time I open DW CS4
        • 1. Re: JPEG Library Editor
          David_Powers Adobe Community Professional
          Unexplained errors like this are frequently caused by a corrupt site cache or configuration folder. The site cache is called WinFileCache-********.dat or MacFileCache-********.dat, and is located inside your personal Dreamweaver configuration folder (the asterisks represent a series of letters and numbers that might differ from computer to computer).
          For Dreamweaver CS4, the configuration folder is at the following location:
          • Vista: C:\Users\<username>\AppData\Roaming\Adobe\Dreamweaver CS4\<language>\Configuration
          • Windows XP: C:\Documents and Settings\<username>\Application Data\Adobe\Dreamweaver CS4\<language>\Configuration
          • Mac OS X: Macintosh HD:<username>:Library:Application Support:Adobe:Dreamweaver CS4:<language>:Configuration
          The Dreamweaver configuration folders are hidden on Windows, so you need to enable the option to view hidden files and folders in order to locate them, as follows:
          • In Vista, select Start > Computer > Organize > Folder and Search Options > View. In Advanced settings, choose Show hidden files and folders.
          • In Windows XP, select Start > My Computer > Tools > Folder Options > View. In Advanced settings, choose Show hidden files and folders.
          First try deleting WinFileCache-********.dat or MacFileCache-********.dat, and restarting Dreamweaver.
          If the problem persists, try deleting or renaming the configuration folder. When you restart Dreamweaver, it will create a new one, and reset all preferences back to their original settings. This usually fixes most common problems with Dreamweaver.
          • 2. Re: JPEG Library Editor
            LostMIke Level 1
            That got the job done, thanks
            m
            • 3. Re: JPEG Library Editor
              tgcllc Level 1
              thank you!
              • 4. Re: JPEG Library Editor
                tgcllc Level 1
                I followed your instructions exactly. Deleted file, restarted Dreamweaver CS4. Didn't help.
                Deleted file, restarted computer. Didn't help.
                Got the error message - not even a file to delete this time. It started up right away when I opened Dreamweaver.
                Anything else I can do?
                • 5. Re: JPEG Library Editor
                  KitBak
                  Could you help me out, I've got the same problem in Dreamweaver CS5 since this morning. Started all of a sudden.
                  JPEG Library Error: "Premature end of JPG file" with OK button. I click the button and it disappears and I can work on the html file in my editor. But often after some changes Dreamweaver quits.
                  • 6. Re: JPEG Library Editor
                    tgcllc Level 1
                    That is bad news! I in fact updated to CS5 and my problems went away. I could not get it fixed in CS4 no matter what I tried.
                    • 7. Re: JPEG Library Editor
                      timtro Level 1
                      What is the cache file location for CS3 in Vista?
                      • 8. Re: JPEG Library Editor
                        kcroy2011 Level 1
                        had this occur in cs5.5. running on Windows 7. Deleted jpegs in the temp folder here:
                        C:\Users\<USERNAME>\AppData\Roaming\Adobe\Dreamweaver CS5.5\en_US\Configuration\Temp\DownloadCache
                        Fixed it. Thanks for your helpful post!
                        This post was very helpful as well:  http://forums.adobe.com/message/1929840#1929840
