At this point I'm just trying out the CF8 .NET service and I can't get it to find even the base system classes.
<cfscript>
objEnv = CreateObject("dotnet","System.Environment");
</cfscript>
The above code fails with the generic java.lang.ClassNotFound exception along with any other class I try to access. The CF .Net service IS running. Can someone point me in the right direction to trouble shoot this please.
I have to admin I haven't done too much in terms of consuming .NET resources in CF, but we used to use a lot of COM objects. I noticed the documentation had the CreateObject type as ".NET" instead of ".dotnet" - thought maybe that might be causing a problem. You could also try type of "COM".
I am running multiple CF8 instances and was missing the dotnet_coreproxy.config file in the Jrun4\servers\{CFinstance}\cfusion.ear\cfusion.war\WEB-INF\cfusion\lib directory
all is well now.
