5 Replies Latest reply on Apr 30, 2009 12:44 PM by ATIF FAROOQ
    Serializing database query results for use as dataproviders
    Cr99 Level 1
      I am executing my database queries in Java and passing my results to flex and creating a chart or datagrid based on the results.  The problem is, I don't know how to code this in Java in a way that flex would understand it.  For instance, Flex wants:
      <mx:DataGrid id="dg"  dataProvider="{myArray}">
        <mx:columns>
               <mx:DataGridColumn dataField="column1" />
               <mx:DataGridColumn dataField="column2" />
                <!-- etc ... -->
               <mx:DataGridColumn dataField="columnN" />
            </mx:columns>
      </mx:DataGrid>
      I need to create this table-like array in Java and have it readable as a dataprovider by flex.  I know about ArrayCollections and Java ArrayLists can be nicely converted to this in Flex, but I just don't know how to create them with a column1, column2, etc. when I don't know from query to query how many columns will be in my results.
      Any help would be greatly appreciated!
        • 1. Re: Serializing database query results for use as dataproviders
          Michael Borbor Level 4
          You don't know in advanced the columns that your queries will return?
          Or the number of records?
          Sincerely,
          Michael
          <mx:DataGrid id="dg"  dataProvider="">
            <mx:columns>
                    <!-- etc ... -->
                </mx:columns>
          </mx:DataGrid>
          • 2. Re: Serializing database query results for use as dataproviders
            ATIF FAROOQ
            hi,
               you can simply construct an xml Structure in java  e.g
               returned record from the database have such fields
               Email:some Email
               Phone Number : Phone Number
               you can build Xml Structure from that e.g
               <Address>
                    <Name>some Name</Name>
                    <Email>some Email</Email>
                     <Phone Number>Phone Number</Phone>
              </Address>
            you can send this xml back in response to flex from java
            then your httpService will automatically serialize that  e.g
            <mx:HttpService url='your java page url' id='javaService'>
            then in your DataGrid
            you can simply
            <mx:DataGrid dataProvider="{javaService.lastResult.Address}"/>
            and if the fields returned from the database are not  consistent then you can ommit DataGridColumn in the datagrid flex will automatically make columsn on the base of the result.
            • 3. Re: Serializing database query results for use as dataproviders
              Cr99 Level 1
              Thanks for the reply.  Xml seems like a good possibility in some cases, but I am actually passing back an object via remoting and then Flex serializes it into Actionscript.  The reason I chose this method was because I need the server to 'push' the data onto flex.  I also have some large datasets to send sometimes, and read that messaging uses AMF format which is faster than XML.
              So I send the java objects in the messages I push out to the flex app and then use the Actionscript equivalents I have serialized to display the data in flex.  Is there a Java equivalent to Flex's XML class?  Or are there other objects I could use in Flex as Dataproviders besides ArrayCollection and Java's ArrayList?
              • 4. Re: Serializing database query results for use as dataproviders
                In Java you can use Collection, Object, Map. But the best will be to
                create dto or vo in Java and in AS
                Sincerely,
                Michael
