1 Reply Latest reply on Apr 30, 2009 3:47 PM by kglad
    Multiple instances of single tween on one layer?
    heathermaus
      Hello all,
      Flash newbie here. I am trying to animate a world map, with dots popping up in various parts of the map as a timeline at the bottom of the page progresses. I have a simple shape tween of a circle that turns from black to green. I need to have 75-100 of these dots appear all over the map at 1-5 frames apart (each tween is about 5 frames).
      Is there any way to put all of these tweens on a single layer, or am I going to be stuck with 100+ layers? The problem I am having with the single-layer method is that every time I add a new instance of the tween by adding a new key frame, then copying the tween and moving the dot on the stage, the previous dot dissappears, and I need the dots to gradually build up until the map is filled with them at the end.
      thanks for the help!
      Heather
