3 Replies Latest reply on May 8, 2009 8:51 PM by heathrowe
    Pop-up menus not aligning properly in Safari
    Kirk Hiner
      I've used Fireworks to generate pop-up menu navigation a hundred times, but this is the first time I've had this problem. The menus work fine in IE, Firefox, etc., but in Safari, the pop-up menus aren't appearing under the button that calls them. They're aligned to the far left of the table in which the buttons sit.
      http://www.affinitymbc.org/index-temp.shtml
      The code looks good to me...I'm getting no errors. I thought it might be an ID conflict, but that doesn't seem to be the case, either. Has anyone else had this problem with Safari? Is there a fix?
      If it helps, I'm using Fireworks CS4 and Dreamweaver CS4, and am using the FireWorks JavaScript code as opposed to CSS.
