2 Replies Latest reply on May 1, 2009 9:59 AM by emiliovick
    Error trying to consume a ASP.NET Web Service
    emiliovick
      Good evevning to the community
      I have a web Service thats request information from the database and display the Records in XML
      example:
      <ArrayOfTitleInfo>
      <TitleInfo>
      <strTitleName>220276</strTitleName>
      <strstore_id>701       </strstore_id>
      <strvoucher_id>146003</strvoucher_id>
      </TitleInfo>
      <TitleInfo>
      <strstore_id>702       </strstore_id>
      <strvoucher_id>146016</strvoucher_id>
      </TitleInfo>
      <TitleInfo>
      <strstore_id>703       </strstore_id>
      <strvoucher_id>146030</strvoucher_id>
      </TitleInfo>
      </ArrayOfTitleInfo>
      I try by this Program to load the Data from The Service but it give me error
      Code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
          backgroundGradientColors="[0xFFFFFF, 0xFFFFFF]">
              <mx:Script>
                  <![CDATA[
                      import mx.controls.Alert;
                      import mx.rpc.events.FaultEvent;
                      import mx.rpc.events.ResultEvent;
                      import mx.rpc.soap.mxml.WebService;
                      import mx.managers.CursorManager;
                      * @bindable
                      * @private
                      * @property Will hold the data passed from the web service.
                      [Bindable]
                      private var _xmlData:XML;
                      * @private
                      * Connects and calls the getPlayers() method from our web service.
                      private function clickHandler(event:MouseEvent):void
                          CursorManager.setBusyCursor();
                          event.target.enabled = false;
                          var service:WebService = new WebService();
                          service.addEventListener(ResultEvent.RESULT, serviceResultHandler);
                          service.addEventListener(FaultEvent.FAULT, serviceFaultHandler);
                          service.loadWSDL("http://www.placespr.com/PLACESPR/placesService2.asmx");
                          service.GetTitleData();
                      * @private
                      * Stores the loaded data in an XML object and displays the DataGrid.
                      private function serviceResultHandler(event:ResultEvent):void
                          CursorManager.removeBusyCursor();
                          _xmlData = XML(event.result);
                          this.dataGrid.visible = true;
                      * @private
                      * Displays any possible errors that might occur when
                      * trying to connect to our web service.
                      private function serviceFaultHandler(event:FaultEvent):void
                          Alert.show(String(event.fault), "Error");
                          this.loadBtn.enabled = true;
              </mx:Script>
              <mx:VBox horizontalCenter="0" verticalCenter="0"
                     horizontalScrollPolicy="off" verticalScrollPolicy="off">
                     <mx:Button id="loadBtn" label="Load/Display Data" width="700"
                         click="clickHandler(event);"/>
                     <mx:DataGrid id="dataGrid" width="100%" height="200"
                         visible="false" dataProvider="{_xmlData.*}">
                         <mx:columns>
                             <mx:DataGridColumn headerText="ID"
                                 dataField="strTitleName" width="30"/>
                             <mx:DataGridColumn headerText="Name"
                                 dataField="strstore_id" width="120"/>
                             <mx:DataGridColumn headerText="Score"
                                 dataField="strvoucher_id" width="70"/>
                             </mx:columns>
                     </mx:DataGrid>
              </mx:VBox>
      </mx:Application>
      Message Error Box
      Thanks in Advance for any help with this problem
      evick
        • 1. Re: Error trying to consume a ASP.NET Web Service
          Gregory Lafrance Level 6
          What is this "input" referred to in the error message? It does not seem to be in your data, but is there a problem in one of your server side scripts with something called "input"?
          • 2. Re: Error trying to consume a ASP.NET Web Service
            emiliovick Level 1
            Thanks for the Quick Response, its Strange because I have a Web Service Located here and on the output Doesn't include Nothing with the tag <input></input>
            The First image of the error are from Internet Explorer, This one came from Mozilla Firefox and are a little different
            Location of The Web Service
            http://www.placespr.com/PLACESPR/placesService2.asmx?op=GetTitleData
            And this is the code in The Web Service
            Public Function GetTitleData() As TitleInfo()
                    Try
                        'create dataset
                        Dim dsTitleData As New DataSet
                        'create connection
                        Dim objCon As SqlConnection = New SqlConnection(ConfigurationManager.ConnectionStrings("dsn").ConnectionString)
                        'create data adapter
                        Dim cmdSQL As SqlDataAdapter = New SqlDataAdapter("SELECT emp_num, store_id, voucher_id FROM voucher", objCon)
                        'fill dataset using data adapter
                        cmdSQL.Fill(dsTitleData, "emp_num")
                        'create object array, using row count as upper dim
                        Dim objTitles As TitleInfo() = New TitleInfo(dsTitleData.Tables(0).Rows.Count - 1) {}
                        'loop through dataset to add data to object array
                        Dim intRsCount As Int16
                        For intRsCount = 0 To dsTitleData.Tables(0).Rows.Count - 1
                            objTitles(intRsCount) = New TitleInfo
                            objTitles(intRsCount).strTitleName = dsTitleData.Tables(0).Rows(intRsCount)("emp_num")
                            objTitles(intRsCount).strstore_id = dsTitleData.Tables(0).Rows(intRsCount)("store_id")
                            objTitles(intRsCount).strvoucher_id = dsTitleData.Tables(0).Rows(intRsCount)("voucher_id")
                        Next
                        'return object array
                        Return objTitles
                    Catch exp As Exception
                        Throw
                    End Try
                End Function
            Thanks for the help
            evick
